RCA CTC195
Discussion in 'Electronic Repair' started by Monica, Jul 6, 2004.
  1. Monica
    Monica Guest
    Help!
    Successfully replaced fuse, however...
    If not, ball park cost to repair?
    Thanx!
    Rookie (do it yourself) Tech
    ~M~
  2. john
    john Guest
    I like it I like it.
    After you changed the fuse WHY did you go into the service menu,s ?
    Tell us the rest of the story.
    kip
  3. Sofie
    Sofie Guest
    oops....
  4. Monica
    Monica Guest
    Because the picture was pinched on top and bottom and the colors
    were out of alignment.
    Any ideas???
    ~M~
  5. john
    john Guest
    Ok ! Then the TV has a problem you going
    into the service menus will not fix a fault.
    First get the set repaired ..
    kip
  6. Monica
    Monica Guest
    kip,
    What's the cost of a replacement part and how difficult to remove and replace...
    or, ball park on what I should expect to pay to have it removed/repaired/replaced???
    ~M~
  7. Art
    Art Guest
    Local RCA authorized service facility will need to be contacted by you ,
    either by phone, mail, or in person. Tell them exactly what you did with
    your set and have them give you a qualified estimate, after the technician
    has a chance to actually evaluate what condition the set is in after your
    FUBAR.
  8. john
    john Guest
    M there is no easy way for the Novice call or take the set
    to a repair shop and get it fixed.If you dont want to do that
    go buy a new set.
    kip
    cc
