Hi...
Wonder if anyone can point me where I might
buy/beg/borrow/steal or download a schematic
for a RCA CTC177 chassis?
Got one here, just went dead. Power supplies
are up but won't turn on. Nothing does anything
Hints and tips also gratefully accepted
Would be great for the cottage could I but get it
going again...
Thanks in advance, and take care.
Ken
This chassis requires speciality tools: RF generator that outputs
specific channels with video of your favorite, dmm to measure the AFT
voltage, also may need scope and chipper check w/ clip adapter is
asoluately required to reinitialize eeprom. Aligning tuner takes
three adjustments for one channel. There is 19 channels total to
align there's 57 adjustments to do, including stereo detection
adjustments too in section 77. The tuner adjustments are in 78 level.
The 76 is for the horizontal freq, horizontal, pincushion, vertical
size & linearity, color balance.
Redoing the solder joints must do the all: Micro shield grounds,
tuner grounds (must take the bottom tin lid off.) repair faq section
has this details.
This is why you need to send this tv to the RCA shop whom does this
daily especially for reintializing and adjustments. Usually 100 to
140 for this job.
Reintializing that eeprom only refreshes the small area for the micro
not the adjustment info areas so there's chances that doesn't need to
adjustment.
Prior to this total failure, I'm wondering why you didn't caught on
there was plenty of warning signs like intermittent snow, top vertical
drop down (not the fold over) etc that signals the grounds IS failing.
Caught early, it's easy and no adjustments usually but this time have
to bite the nail and pay someone to straighten tv out.
Cheers,
Wizard
