RCA CTC177 chassis
Discussion in 'Electronic Repair' started by rockitroll, Nov 5, 2004.
  1. rockitroll
    rockitroll Guest
    unit works fine until warm then screen gets too bright with retrace lines
    .... can turn down screen voltage all the way but when its cold then its too
    dark ...repair tips say c5002 , and c5004 on crt board .... tuner grounds
    have been done before , still holding ... any help would be awesome , thanks
  2. rockitroll
    rockitroll Guest
    got it , the q5004 video buffer transistor on the crt board was leaking ...
    caps were fine per esr meter
  3. Jim Lazzaro
    Jim Lazzaro Guest
    It is probably a faulty diode or transistor; your best thing to try is
    when the unit is warm just freeze spray small sections on the board
    and you should be able to see the change you mentioned. Narrow your
    search with the spraying and you should be able to pinpoint the
    culprit. good luck.
    Jim
