RCA 27" Tv, odd problem.
Discussion in 'Electronic Repair' started by Dani, Oct 10, 2007.
  1. Dani
    Dani Guest
    Model # 27R410T Chassis ITC008FAM. Was repaired for going off
    horizontal months ago. Now,
    sometimes it works ok, other times it won't start, just shuts right
    down, with no high voltage. When it's running, all the SMPS
    secondaries roam around a bit, but settle down if the G 2 is set "just
    right" Then it works fine. Are the flybacks so crappy, that it can
    make the set unusable, if set wrong or "drift" slightly? Dani.
  2. Meat Plow
    Meat Plow Guest
    Sounds like a reasonable assumption.
  3. Art
    Art Guest
    Especially if an aftermarket LOPT has been installed when the original
    failed.
