RC5 IR remote decoder using 12 LEDs
Discussion in 'Electronic Basics' started by Bill Bowden, Nov 5, 2012.
  1. Bill Bowden
    Bill Bowden Guest
    I'm attempting to construct an IR receiver circuit capable of
    receiving and displaying IR signals in binary format (using LEDs) from
    hand held IR remote controls. The protocol I'm interested in is the
    RC5 format originally developed by Phillips. The format consists of 2
    start bits followed by a toggle bit indicating a new key is pressed,
    followed by 5 address bits, and then 6 command bits for a total of 14
    bits. I plan to display the bits using 12 LEDs. The RC5 code uses a
    system where each bit is one cycle of equal time where a "1" is
    represented by the first half cycle
    being low followed by the second half cycle high and visa versa for a
    "0". This yields a weird waveform where the end of one bit may be the
    same level as the beginning of the next. What would be the best
    approach to decode the data using a couple shift registers and some
    sort of clock to sample the data at the right time?
    -Bill
  2. Jasen Betts
    Jasen Betts Guest
    look up manchester code, because that's what you've got.
    esasiest decode is probably to rely on the state changing in the
    missle of each bit and use that change to trigger your bit clock.
  3. tuinkabouter
    tuinkabouter Guest
    Have a look at lirc. It can decode a lot of remote controls.
  4. Bill Bowden
    Bill Bowden Guest
    Problem is, it's hard to see the middle of the bit when the levels may
    be changing at a 1.778 mS rate, or half that at a 889uS rate depending
    if the code is all ones or zeros, or alternating ones and zeros. Some
    of the clock edges may be missing, so it's hard to synchronize a
    clock. For example a code of all ones or zeros would be a series of
    narrow pulses, while a code of alternating ones and zeros would be a
    series of wider pulses. The total number of data edges is not
    constant. I think I might figure it out using a pic processor and
    measuring the time intervals between edges, but I thought there might
    be an easy hardware solution.
    -Bill
  5. Jasen Betts
    Jasen Betts Guest
    The middles are approx 1.778ms apart, so at each middle start a one-shot
    that runs for 1.3ms, while it's on ignore every transition.
    Should be possible with 3 DIP parts and few passives on a 50 column
    solderless breadboard.
    http://lmgtfy.com/?q=manchester+code+decoder+hardware+schematic
    The firat hit appears to be undergraduate lab notes from an Indian
    university, the schematic has unreadable part numbers but may be
    enough for inspiration.
  6. Daniel Pitts
    Daniel Pitts Guest
    The change direction is what specifies the data value. The only
    difficulty I can see is filtering out which transition is the "Data"
    transition, and which one is just the boundary between two clocks.
    Perhaps a PLL would help?
    Take my comments with a grain of salt, as they are basically what I've
    gleaned from a few minutes on Wikipedia :).
  7. Bill Bowden
    Bill Bowden Guest
    John, the simulation worked fine but took several hours to complete.
    My question now is how to save the simulation data so I can close
    LTspice and come back later to review the simulation without starting
    over. I didn't see an easy way to do this.
    -Bill
  8. Bill Bowden
    Bill Bowden Guest
    Yes, that works. I can get back to the sim without re-running it. I
    downloaded the datasheets for the 595, 191, and 40103. Interesting
    chips I haven't seen before. I guess you are counting down from 1778
    to zero to get the strobe to see the data in the right place every
    1.778 mS. Need more time to study it all.
    -Bill
  9. Bill Bowden
    Bill Bowden Guest
    Sure, if you want to write it up. I was wondering how the whole thing
    got into sync on the rising edge of the start bit. That's the hard
    part. I see an output at pin 1 of the 'HC32 or gate' which sets the
    AB flip flop and controls the preset condition of the down counters.
    The function of the HC191 is elusive. How does the circuit know when
    the end of transmission occurs and it's time to reset and get ready
    for the next transmission?
    -Bill
