rc timer circuit help
Discussion in 'Electronic Basics' started by [email protected], Jul 10, 2013.
  1. Guest
    Hi
    I have a GSM controller that can switch a relay for a minimum time of 1 sec, however I need a 300ms pulse. I am looking for a circuit that can take the 1 sec relay output (as an input) and give me a 300ms output for a second relay.
    Thanks for any help.
  2. Jon Kirwan
    Jon Kirwan Guest
    Does the 300ms start at the beginning of the 1s output
    duration or at the end of it? In any case, have you looked at
    the 74121 (various families), 74HC221, or 74HC123 to use
    together with an external BJT or MOSFET switch?
    Jon
  3. Jasen Betts
    Jasen Betts Guest
    how precise do you need to be?
  4. Guest
    Hi
    Does not need to be that precise but should be below 500ms.
  5. Guest
    The out put is a dry contact relay.
  6. whit3rd
    whit3rd Guest
    If this were a system with DC power supply, and logic-level output, it's easy. If it's
    an AC-power (mains) system, things get trickier: the best might be an AC timed relay
    connected in series, that turns OFF after 300 msec, and resets when power is
    removed.
    It matters a lot what kind of power is available (and what the nature of the intended
    load is).
  7. Guest
    Thanks all, going with the capacitor, resistor suggested by John, simple and effective.
  8. Fred Abse
    Fred Abse Guest
    Named for a Kansas City undertaker.
