RC 3 wire battery charging
Lurch180
Aug 16, 2017
15
Aug 16, 2017
15
Hi, can you please help me sort this battery charging problem.
My grandson has lost the charger for his RC car.
I am a little confused with how to charge it, it has three wires.
It has a Red, Black and a Blue.
It is a QL NI-CD AA 700mAh 9.6V
I am unable to find a charger for it online, in the usual places.
I have put a DVM across the pins and I am getting
9.2V across Red and Black with the Red one being +ve
2.6V across Red and Blue with the Red one being +ve
6.6V across the Blue and Black with the Blue one being +ve
Any advise on buying a charger or how to connect one to the 3 pins will be greatly appreciated.
Thank you
Lurch
Harald Kapp
13,744
13,744
I assume that this is a 9.2 V pack (red='+', black='-') for the motor with an internal tap on 6.6 V (blue='+', black='-') for the receiver.
Similar to this one only with slightly less capacity?
I'm not aware of any charger that will handle the 6.6. V port separately. It is probably o.k. to charge this battery with any charger suitable for 9.2 V (8 cells) rechargeable NiCd batteries. Use the 9.2 V (red/black) wires for charging. A matching charger is e.g. this one. You will haev to build your own connector and/or adapter to match/mate to the connector on the battery.
Lurch180
Aug 16, 2017
15
Aug 16, 2017
15
Thanks for quick reply, I will try to charge it through the red and black leads.
Thanks Harald
