T
TimJay
Need info about the Open Array 72" verse 48"
Larry W4CSC said:In any radar system, from any manufacturer, you need to think about how far
it is to the horizon from the altitude your antenna is located. Ask
yourself, "Can this system give me good returns from a normal boat at the
horizon?" It cannot see beyond its horizon. Its horizon is dependent on
its altitude. Altitude is also a tradeoff with close-in target acquistion.
If you put the antenna up high to get a longer horizon, you won't be able
to see that damned bouy someone put in your way in the fog you are about to
run over. I'll trade seeing that bouy in really close to the boat for
seeing a boat out 35 miles any day of the week. Of course, having two
radars, one low down to see that bouy and one up high to see those long-
range targets is much nicer. It also gives you redundancy for the
inevitable failures of these cheaply made boat systems.
A 72" array WILL have a narrower beamwidth than the 48". A narrower
beamwidth translates into resolution, not range, of the targets on the
scope. Instead of the two targets out there painting as one wide one, you
MAY be able to see them as two distinct targets, as if that really made any
difference. AS you get closer to the targets, the wider beamwidth antenna
also shows them as separate targets closer in, which I think makes the
point moot. The higher power of the 72" transmitter WILL show small
targets like towers and bouys at larger ranges by painting them with more
brute RF power force, creating a larger return signal above the noise floor
of the receiver. If seeing a bouy 18 miles away instead of 10 miles away
is important to you, the higher the power the better. If under sail, with
limited power resources, higher power eating the batteries soon becomes
more important than seeing the bouy so far away. At 30 gallons per hour,
it matters little.
Hope this makes you think of your particular situation. Everything is a
compromise.
Open Arrays are really SlotLine Waveguide Antennas, and legnth is
proportional to Antenna Gain, and Transmitted Peak Power. It is also
Inversely proportional to Horozontal Beamwidth. More is better, for
all cases, and less beamwidth is better always. I only have one nit to
pick with Larry's above, and that is Detection Distance for any
particular target is a combination of all the above factors and a few
more, but one of the biggies is Peak Transmitted Power, More power,
equals better targets, at longer ranges. In the old days before Loran,
and GPS, Radar was used for Position Fixing, and mountains were often
used as targets for navigation, at ranges exceeding 72 miles, with the
Decca 3xx, and 4xx series radars that had 20Kw and 40Kw XBand
transmitters with 6 and 7.5 Ft antennas.
Rule of thumb: Bigger is better, longer is better , but all this
"better" costs alot more money. So, eventually money is the limiting
factor.
Bruce in alaska
I agree with Bruce, bigger is always better. The larger array provides
narrower beam width along with higher gain. The narrower beam width
will help with target resolution on all ranges. It can be most
appreciated on the shorter ranges where Larry says it does not matter.
When on a narrow waterway the larger array will allow you to
distinguish a boat from shore objects that can not be done on the
small radar's.
The higher power will let you see small objects like those small buoys
that the small radar's may not even see.
A note on peak power. It is really the amount of average power that
determines how much of a return you get from the radar. The higher the
average power the better return.
The wider the pulse width of the radar pulse the greater the average
power transmitted. But the wider the pulse width the less resolution
in range you have. This is particularly important on short ranges.
This is why most radar's use a wide pulse width for long range (gives
higher average power) and very narrow pulses on short range. The
narrow pulse gives much better range resolution but lowers the average
power of the signal. But at short ranges you can get by with less
average power because signal returns are generally stronger.
The peak power of the transmitter usually remains the same whether
long or short pulses are being used. It is necessary to have a rather
high peak power transmitter in order to achieve enough average power
for decent returns as pulse widths are narrowed.
With a given pulse width, the higher the peak power of the transmitter
the higher the average power will be.
Some radar's have poor range resolution because they are under powered
and have to use wider pulses (to raise the average power) in order to
get strong enough returns on ranges where the pulses being used should
be narrower for better range resolution.
Usually radar's are advertised by how much peak power they have.
Sounds more impressive. Few tell you what the actual average
transmitted power is which is the most important.
Regards
Gary
One thing I see missing as to short range is the TR time...i.e., how
quickly after the tx pulse quits can the rx receive and process the
echo. It's possible to "blind" the rx even if the isolation between
tx/rx is 100 dB or better. Anyone know some numbers?
Navy? AN/SPS-6? SPS-55? SPS-30? SPS-21, the old Raytheon Pathfinder?Norm B (who has never worked on a solid-state radar, but has on
tube type 2 and 5 mega Watt ones)
One thing I see missing as to short range is the TR time...i.e., how quickly
after the tx pulse quits can the rx receive and process the echo.
It's possible to "blind" the rx even if the isolation between tx/rx is 100 dB or better.
Been there, done that, got the T-shirt...(c; Old Navy Fart, here. The 30
could see the moon if you kept keying the repeater with pulses on its
trigger input. It would kill a seagull in its beam out several hundred
yards.
it used a klystron rather than a maggie. Strange beast, but reliable.
