Rayleigh Fading Channel Simulation?
Discussion in 'Electronic Basics' started by Davy, Mar 6, 2006.
  1. Davy
    Davy Guest
    Hi all,
    I have got a Rayleigh Fading Channel Simulation code by Matlab.
    The code list below:
    % Rayleigh fading
    a = sqrt(0.5)*( randn( 1, symbols_per_frame) + j*randn( 1,
    symbols_per_frame) );
    % complex noise
    noise = sqrt(variance)*( randn(1,symbols_per_frame) +
    j*randn(1,symbols_per_frame) );
    % in all
    code_fade = a.*code + noise;
    Is the code right? If not right, how to modify it?
    Best regards,
    Davy
  2. Mike Yarwood
    Mike Yarwood Guest
    You might want to low-pass filter a to give you rayleigh fading which isn't
    quite so broadband - this looks white to me.
    Also may want to scale a so that you get a particular fade probability
    w.r.t. mean predetection signal power.
    Best of luck - Mike
