T
Terry Pinnell
Franc Zabkar said:Not necessarily. The most common PWM controller IC is the TL494 or its
equivalent, KA2500B/C. All you need to do is to confirm the voltages
at the inputs to the IC's error amp. One input will usually be 2.5V (=
internal 5.0V reference divided by 2), the other input will be derived
from the +12V rail and/or the +5V rail via a resistive potential
divider. All you need to do is to recompute the resistor values in the
feedback network so that the target voltage, eg 13.8V, produces 2.5V
at the input to the error amp.
The two that I modified were both AT types. I had the schematics for
neither. Only very minor reverse engineering was required.
- Franc Zabkar
Mine has no manufacturer's name on the case, only 'Model PTP-2006'. It
is 200W and has +5V @20A (red), +12V @ 8A (yellow); -5V @ 300mA
(white); -12V @ 300mA (blue); 0V (black); and an orange wire marked
'PG', the purpose of which I'm unsure about.
