Raspberry Pi V. Arduino
Discussion in 'Microcontrollers, Programming and IoT' started by Dylan Wisdom, Apr 13, 2014.
  1. Dylan Wisdom
    Dylan Wisdom
    26
    Apr 10, 2014
    What is the main differences between what Raspberry Pi does and what Arduino does?
  2. kpatz
    kpatz
    330
    88
    Feb 24, 2014
    In short, Raspberry Pi has a more powerful processor that runs Linux. Arduino uses a simple microcontroller that is programmed in C or Assembly. Similar in principle, but they have different capabilities and applications.
  3. Anish
    Anish
    46
    Feb 5, 2011
    In simple words,
    Arduino ~ Nokia 3310
    Raspberry pi ~ nokia lumia 1020
  4. ranger306ci
    ranger306ci
    Apr 5, 2011
    IMO, arduino is easier to use from the get go. The language and setup are simple.
    However, if you can code in python, the pi is more powerful.
    For most imbedded projects, the arduino is plenty.
  5. Thedarkb123
    Thedarkb123
    29
    Apr 15, 2014
    For most projects you don't even need an arduino, just an AVR and maybe a crystal.
  6. (*steve*)
    25,489
    2,830
    They really fooled you didn't they?
    That's C++ you're coding in. The setup might be simple, and the examples may be simply coded, but don't let that fool you. If you start looking at other people's library routines you'll find out real fast.
  7. Dylan Wisdom
    Dylan Wisdom
    26
    Apr 10, 2014
    Could you use both Arduino and Raspberry Pi on the same project? Could they work together?
  8. (*steve*)
    25,489
    2,830
    Sure.
  9. kelvinmead
    kelvinmead
    16
    Nov 22, 2011
    arduino is better at external hardware, buttons, leds, integrating with permanent solutions
    raspberry pi is better for coding with, plus you can see what you are doing.
