Rascal house alarm
neil
Jan 20, 2012
Jan 20, 2012
Hi
I have a Rascal alarm which has been installed for about 10 years and has worked without any problems. Yesterday I had cause to switch electricity off and switched it back on about an hour later. When I tried to put the alarm on last night I noticed that non of the lights on the key pad box were illuminated and I was unable to enter my alarn code. Do you think that the internal battery has gone?
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
If it hasn't been changed in 10 years it's certainly "a goner". Five years is the normal replacement interval.
Here's a recent thread on this forum about a similar alarm by the way.
There may be a T1A 20x5mm fuse in connection with the battery. Better check that too while you're in there.
I don't know if replacing the battery will fix your problem though.
neil
Jan 20, 2012
Jan 20, 2012
Thanks alot. I have replaced the bateery and everything is fine
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Place a note somewhere visible that reads "Replace battery in 2017"
