Random timer!
Discussion in 'Electronic Basics' started by Baron, May 31, 2007.
  1. Baron
    Baron Guest
    Hi John,
    John Fields inscribed thus:
    Just remove the .nospam
  2. Baron
    Baron Guest
    Hi Jason,
    Jasen inscribed thus:
    Can you confirm the resistor value between pin 2 and 7 please !
    I read it as 33 Ohms ?
  3. Baron
    Baron Guest
    Hi Bob,
    Bob Masta inscribed thus:
    Right lets see if I've got this right !
    I've breadboarded the 555 timer circuit from Jason. This is the clock
    input to a SN74194 via an AND gate. The outputs are OR'ed so that if
    any one is high the output is high. This output starts the counter
    when it goes low.
    The 555 goes fast incrementing the 74194 until the button is pressed.
    When this happens the 555 runs slow and the 74194 is decremented.
    When the 74194 hits all zeros the OR'ed output starts the counter,
    turns on a light and gates off the 555 output.
    Pressing the second button resets everything.
    I hope that it makes sense ! It does to me now that I realised that
    the random element was the time between button presses !
  4. John Fields
    John Fields Guest
    I think you've still got it wrong. Consider:
    Using Jasen's method, at startup the 555 will be oscillating at,
    say, 1000 Hz and it'll be clocking a free-running 4 bit binary
    counter (not a shift register) so that its outputs change every
    millisecond. That's fast enough that a random number between 0 and
    15, inclusive, will be captured when the start button is pressed.
    Now, when the START button is pressed, the 555's speed will be
    changed to 1Hz and the counter's TERMINAL COUNT (TC) output will be
    connected to the counter's ENABLE input so that when the counter
    gets to 1111 it'll freeze.
    When that happens, the 555's speed will be changed back to 1000Hz,
    the lamp will light, and the reaction time counter will be enabled,
    allowing it to accumulate 1000Hz clocks until the STOP button is
    pressed. At that time the reaction time counter will be stopped and
    its output frozen.
    The 555 will be allowed to remain oscillating at 1000 Hz, however,
    and the 4 bit binary delay counter will once again start
    free-running until the START button is pressed, renewing the cycle.
    Want a schematic?
  5. Baron
    Baron Guest
    Yes please. By the way I sent a mail to you at the address in the
    from line. Hope thats Ok.
  6. Jasen
    Jasen Guest
    that 555 circuit was my original suggestion, at the time I wasn't aware of
    a need for an an the delay to be a whole number of seconds...
    (I still haven't seen a requirement for that)
    Bye.
    Jasen
  7. Jasen
    Jasen Guest
    that's right the LM555 has a maximum current into the discharge pin
    of 200mA, (and the CMOS version TLC555 or 7555 only 100ma)
    33ohms is enough to keep the peak discharge current to a
    sensible value with a 5V supply the capacitor will charge to 3.33V
    so the peak dischharge current will be about 100mA
    Bye.
    Jasen
  8. Baron
    Baron Guest
    There isn't ! I am just feeding a shift register which gives 1, 2, 4,
    8, outputs. OR'ed together gives a high out while the count is not
    zero. Stepping the register backwards with a 1 second clock causes
    the OR'ed output to go low when zero is reached.
    Your 555 dual speed clock works as advertised.
    Thankyou.
  9. John Fields
    John Fields Guest
    Yes, that's fine.
    I just emailed you the schematic and also posted it to abse in case
    anyone else is interested. If you have any questions about how it
    works, please post them here instead of emailing them to me so that
    the discussion will remain public.
  10. Baron
    Baron Guest
    Hi John.
    I don't know if there is a problem or not with the mail ? I haven't
    received anything from you yet !
    Thanks.
  11. John Fields
    John Fields Guest
