Random timer!
Discussion in 'Electronic Basics' started by Baron, May 31, 2007.
  1. Baron
    Baron Guest
    Hi Guys,
    I'm looking for ideas here. I am trying to figure out how to make a
    random interval timer! Something that will trigger an indicator
    after a random period of time. Ideally 1 to 15 seconds after a button
    is pushed.
    Thanks.
  2. Jan Nielsen
    Jan Nielsen Guest
    A PICAXE 08 will do it, although if you dont seed the random with
    something dynamic, it will be the same pattern after every boot.
    The pic is 1.5gbp or so, programmed in basic or flowchart trough 2
    resistors, so cheap to get started with.
    http://www.rev-ed.co.uk/picaxe/
    /Jan
  3. Jasen
    Jasen Guest
    have a fast oscilator the becomes a slow oscilator when the button is pressed.
    (period of 14 seconds) add a 1 second delay
    Bye.
    Jasen
  4. Baron
    Baron Guest
    Hi Jasen, inscribed thus:
    I like that idea... but how would you implement it ?
  5. Baron
    Baron Guest
    Hi jan,
    Jan Nielsen inscribed thus:
    I've never used pickaxe. Thanks for the link, I'l go and have a look
    at it.
  6. John Fields
    John Fields Guest
    Do you want it to be an integral number of seconds from when the
    button is pushed or are you looking for a pulse with a truly random
    width starting 1 second after the button is pushed and ending at any
    time up to and including 15 seconds after the button was pushed?
    Better yet, what's your application?
  7. Baron
    Baron Guest
    Hello John,
    John Fields inscribed thus:
    This is intended as a reaction timing device. The user pushes a
    button and after a random delay, pops a light on and starts a
    counter. The user presses a second button that stops and freezes the
    counter. A little like the "Simon" toy but with a counter instead of
    a buzzer. Fixed delays ie 1, 2, 4 etc seconds is easy. I didn't
    think a random delay would be so hard !
  8. Rich Grise
    Rich Grise Guest
    Just use a PSRG (pseudorandom number generator). Let it free-run, and
    when the button is pressed, use the PSRG's current value to select one
    of your 15 fixed delays.
    Good Luck!
    Rich
  9. John Fields
    John Fields Guest
    It isn't, it's just that your description is confusing and isn't
    detailed enough to allow a design to be done.
    From your second description I take it that you want a device which,
    after a button (START) is pushed, waits for between 1 second and 15
    seconds to turn on a light and simultaneously start a counter then,
    when a second button (STOP) is pressed, stops the counter while
    preserving the value of the count it has accumulated.
    What you haven't said is whether you want the delay to occur in
    random increments of one second and what granularity you want from
    the reaction time counter. That is, 1s? 100ms? 10ms? ???
    You also haven't addressed how you want the reaction time counter to
    be reset if you're doing multiple runs.
    A good way to do it would be to have the START button do it at the
    beginning of each run, unless you have a better idea.
  10. John Fields
    John Fields Guest
    I've made a few assumptions and posted a schematic to abse.
    The device should work like this:
    1. When the START button is pushed, a four-bit pseudo-randomly
    generated number is loaded into a four bit binary delay counter
    and the counter enabled.
    2. The PRSG is advanced to the next state.
    3. The counter's one second clock is started.
    4. The four BCD digit reaction time counter's outputs are cleared.
    When the delay counter times out:
    1. The delay timer is disabled and latched up.
    2. An LED is turned on.
    3. The reaction time counter is enabled.
    4. The 1000Hz reaction counter clock is started.
    When the STOP button is pressed:
    1. The reaction time counter is disabled and its outputs frozen in
    the state they were in when the STOP button was pressed.
    When the START button is pressed again, the new pseudo-random number
    will be loaded into the delay counter and the cycle started anew.
    One caveat: One of the allowed states of the PSRG is 1111, which
    will cause the LED to come on as soon as the START button is
    pressed, so instead of 15 random delays from 1 second to 15 seconds
    you'll have 16 random delays from zero seconds to 15 seconds.
    It's a feature, not a bug. ;)
  11. Baron
    Baron Guest
    Hi John,
    Unfortunately abse (alt.binaries.schematics.electronics) is not a
    group I have access to. My service provider doesn't provide news
    services any more. First they stopped posting and now they have been
    discontinued altogether. This server is the only one I can read and
    post to.
  12. Baron
    Baron Guest
    Yes that's it exactly
    The clock to the counter is at 1Khz.
    That is what I am doing now. Pushing the start button resets the
    counter to zero.
    This is the bit that I am struggling with !
    Sounds good !
  13. http://www.usenet-replayer.com/groups/index.html
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  14. John Fields
    John Fields Guest
  15. Baron
    Baron Guest
    Done ! Thank you John.
  16. Jasen
    Jasen Guest
    I'd probably do it software, but if pressed to do it in hardware
    it'd be based around this:
    here's the variable-rate bit done using a LM555 tiomer chip,
    (it's not perfect one time in 1000 (or so) it'll fire immediately instead of
    waiting "randomly" 0-14 seconds but I'm guessing from your description
    that's not an issue...
    | This is an ascii schematic, if the diagram appears garbled |
    | try switching to a fixed-pitch font (courier works well) |
    | pasting it into notepad works well on ms-windows. |
    | or in google groups "view source" (found under options) |
    500K slow rate
    .-\/\/\--+--------+--- +5V
    \ | . VCC(8) .
    / 1.2M | . .
    \ `--RES(4) OUT(3)--------->
    | . 555 .
    go-fast ----\/\/\-->|-+--------+--TH(6) DIS(7)-----.
    10K 1N914 | . . |
    +--TR(2) CV(5)-- |
    | . GND(1) . |
    | | 33
    10uF | |
    --+--------+-- 0V
    +5V on go fast will make it run at about 100Hz - faster than human
    reactions.
    pur 0V on go fast and the rate is determined by the trimmer at the
    top, set that so that the circuit pulses once every 14 seconds with
    go-fast held low. (best way to detect the pulses may be cheap
    headphones in series with a 1K resistor on the output, the pulse will
    it'll probably be too short to easily see on a LED)
    the rest of the circuit depends on exactly what you want.
    assuming the start switch is a momentary push button,
    is it acceptable to require that the operator to hold it down
    until the random trigger ?
    can I use a two pole switch to make the design easier or is only
    single pole available, can the switch be floating or must one end be
    ground or +5v
    what sort of output do you need is a floating LED acceptable or must
    it be ground referenced ?
    what behavior do you want from the output?
    Bye.
    Jasen
  17. Baron
    Baron Guest
    Jasen inscribed thus:
    Yes I have been caught out by not using fixed pitch fonts before !
    The indicator and counter should come on together !
    No ! Once pushed the operator has to be able to press a second
    button. This stops the counter and latches the display until the
    first button is pressed again.
    The switches I used are the momentary ones from computer reset
    buttons.
    What happens at the moment is a monostable flips state, 0 - 5v TTL
    logic.
    It won't take me long to breadboard this up so that I can play with
    it. If it works well then that will be great.
  18. Bob Masta
    Bob Masta Guest
    Jasen's original suggestion makes a great pseudo-random generator.
    Just have a 4-bit counter counting a fast clock. When the START
    button is hit, the counter will be at some random value (random
    due to the random timing of the START press relative to the
    high-speed clock). You just have to switch off that clock and
    switch to a low-speed clock for your count-down. (You can
    switch the timing values in a single clock, or have 2 separate
    clocks for this.)
    Best regards,
    Bob Masta
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
    Scope, Spectrum, Spectrogram, Signal Generator
    Science with your sound card!
  19. Baron
    Baron Guest
    Hi Bob,
    Bob Masta inscribed thus:
    This seems silly ! But I just can't seem get my head around it ! This
    is what I have at the moment.
    I have a 1Khz clock and a one second gate time which feeds a four
    digit display. The one second clock is counted by a four bit counter
    to give 1, 2, 4, 8, seconds delay using diodes and a switch to select
    1 to 16 seconds.
    The display is four digits fed from the 1Khz clock gated by the 1
    second clock. This is started by a monostable triggered from the
    delay timer and triggered back by the stop button.
    This works fine. I just don't seem to be able to see the wood for the
    trees !
  20. John Fields
    John Fields Guest
    For some reason I didn't get your email addy, so if you'll send it
    again (or post it here with sufficient munging to foil the
    harvesters) I'll be able to send you my circuit.
    BTW, here's the PRSG in LTSPICE, with a fix so it has a minimum
    delay of 1 second (the "feature" was fixed ;):
    Version 4
    SHEET 1 2076 1144
    WIRE 480 -816 -352 -816
    WIRE 592 -816 480 -816
    WIRE 752 -816 672 -816
    WIRE -416 -768 -592 -768
    WIRE 240 -752 -352 -752
    WIRE 240 -704 240 -752
    WIRE 592 -704 240 -704
    WIRE 752 -704 752 -816
    WIRE 752 -704 672 -704
    WIRE 240 -640 240 -704
    WIRE 240 -640 -352 -640
    WIRE 0 -608 -352 -608
    WIRE -416 -592 -528 -592
    WIRE 0 -592 0 -608
    WIRE 592 -592 0 -592
    WIRE 752 -592 752 -704
    WIRE 752 -592 672 -592
    WIRE -256 -576 -352 -576
    WIRE -592 -528 -592 -768
    WIRE -528 -528 -528 -592
    WIRE -256 -496 -256 -576
    WIRE 592 -496 -256 -496
    WIRE 752 -496 752 -592
    WIRE 752 -496 672 -496
    WIRE -128 -480 -384 -480
    WIRE 128 -480 -128 -480
    WIRE 368 -480 128 -480
    WIRE 512 -480 368 -480
    WIRE -384 -432 -384 -480
    WIRE -128 -432 -128 -480
    WIRE 128 -432 128 -480
    WIRE 368 -432 368 -480
    WIRE -544 -384 -544 -464
    WIRE -464 -384 -544 -384
    WIRE -256 -384 -256 -496
    WIRE -256 -384 -304 -384
    WIRE -208 -384 -256 -384
    WIRE 0 -384 0 -592
    WIRE 0 -384 -48 -384
    WIRE 48 -384 0 -384
    WIRE 240 -384 240 -640
    WIRE 240 -384 208 -384
    WIRE 288 -384 240 -384
    WIRE 480 -384 480 -816
    WIRE 480 -384 448 -384
    WIRE 752 -384 752 -496
    WIRE -496 -336 -624 -336
    WIRE -464 -336 -496 -336
    WIRE -208 -336 -240 -336
    WIRE 48 -336 16 -336
    WIRE 288 -336 256 -336
    WIRE -624 -320 -624 -336
    WIRE -496 -256 -496 -336
    WIRE -240 -256 -240 -336
    WIRE -240 -256 -496 -256
    WIRE 16 -256 16 -336
    WIRE 16 -256 -240 -256
    WIRE 256 -256 256 -336
    WIRE 256 -256 16 -256
    WIRE -624 -208 -624 -240
    WIRE -384 -208 -384 -288
    WIRE -384 -208 -624 -208
    WIRE -128 -208 -128 -288
    WIRE -128 -208 -384 -208
    WIRE 128 -208 128 -288
    WIRE 128 -208 -128 -208
    WIRE 368 -208 368 -288
    WIRE 368 -208 128 -208
    WIRE 512 -208 512 -480
    WIRE 512 -208 368 -208
    WIRE 752 -208 752 -304
    WIRE 752 -208 512 -208
    WIRE -624 -176 -624 -208
    FLAG -624 -176 0
    SYMBOL Digital\\dflop -384 -432 R0
    SYMATTR InstName A1
    SYMATTR SpiceLine vhigh 5v trise 88e-9 tfall 88e-9
    SYMBOL voltage -624 -336 R0
    WINDOW 3 24 104 Invisible 0
    WINDOW 123 0 0 Left 0
    WINDOW 39 0 0 Left 0
    SYMATTR Value PULSE(0 5 0 50e-9 50e-9 .5 1)
    SYMATTR InstName V1
    SYMBOL Digital\\dflop -128 -432 R0
    SYMATTR InstName A2
    SYMBOL Digital\\dflop 128 -432 R0
    SYMATTR InstName A3
    SYMBOL Digital\\dflop 368 -432 R0
    SYMATTR InstName A4
    SYMBOL Digital\\xor -400 -720 R180
    SYMATTR InstName A5
    SYMBOL Digital\\and -384 -672 M0
    SYMATTR InstName A6
    SYMBOL Digital\\xor -496 -480 R90
    SYMATTR InstName A7
    SYMBOL res 688 -832 R90
    WINDOW 0 -34 58 VBottom 0
    WINDOW 3 -35 57 VTop 0
    SYMATTR InstName R1
    SYMATTR Value 160k
    SYMBOL res 688 -720 R90
    SYMATTR InstName R2
    SYMATTR Value 80k
    SYMBOL res 688 -608 R90
    SYMATTR InstName R3
    SYMATTR Value 40k
    SYMBOL res 688 -512 R90
    SYMATTR InstName R4
    SYMATTR Value 20k
    SYMBOL res 736 -400 R0
    SYMATTR InstName R5
    SYMATTR Value 330
    TEXT -584 -184 Left 0 !.tran 20
    When you run it, The horizontal axis corresponds to successive
    pressings of the START switch (after the STOP switch has been
    pressed) and the vertical axis corresponds to the numerical value of
    the shift register's output, where 10mV = 1, 20mV = 2, and so on.
    The resistor network is a DAC used to generate the vertical data and
    isn't used in the actual circuit.
