S
Stoatgobbler
Hi there,
I'm building a JL Hood hifi amplifier and to construct the power
supplies I've mounted two toroidal transformers in a case, one on top of
the other. Each toroid has two secondary windings which I'm going to use
to create two separate, independent, regulated +22v - 0 - -22v power
supplies. To make these power supplies truly independent (and to reduce
the chances of earth loop hum) I've "lifted" each power supply 0v common
from the chassis earth via 60ohm resistors.
On testing the power supplies I've noticed that the greater the current
I pull out of each power supply the greater the potential difference
that appears across the 60ohm resistor (chassis earth to power supply 0v
line). when I pull 1.1A from the power supply then I have nearly 17v
across the 60ohm resistor. This voltage does not seem to vary with
raising the upper toroidal away from the lower so I don't think the size
of this voltage is to do with interactions between the two (but would
stand to be corrected).
I've never "played" with this, I did expect a voltage across it (due to
eddy currents within the transformer normally "lost" in heating the iron
core in a conventional E I type transformer?) but I thought toroidals
minimised this and the voltages resulting from this would be
nominal....17v across 60ohm is not nominal.
Is this normal or is something going on?
Any advice or comments would be appreciated.
Stoat
Stoat
