Rainbow picture on panasonic tv
Discussion in 'Electronic Repair' started by splitwit, Nov 15, 2006.
  1. splitwit
    splitwit Guest
    Hi does anyone know what part needs to be replaced on a CT-32SF36
    Panasonic Tv to stop the rainbow picture???
  2. b
    b Guest
    splitwit ha escrito:
    degauss posistor or if its had a knock, the tube....
  3. Guest
    If the degauss is working ok, it'll be the shadowmask. Enjoy it as it
    is, or if you cant do that, try giving it a good hard whack in a few
    directions, which will either fix it or kill it for good.
    NT
  4. David Naylor
    David Naylor Guest
    Sounds like this set was dropped or hit hard and your shadow mask has
    let loose your need a pix tube big money
  5. Guest
    Both myself and brother have this TV. We had the same problem. Your
    set needs to be degaussed. That's it, PERIOD. It is a magnetic loop,
    plugged into AC, waved in a circular motion around the front of the
    tube on your TV. That's it. Rent or borrow one. Dirt cheap to fix.
    Sincerely, Humbled
