Kind Sire . . . . . . . . .
Prithee, what type of meter doth thou be using, AND its brand and manufacturers model number.
Also, do think back, not too long ago, when your next block neighbor, Delmer A Dumbnuttz, was wanting to check out his air conditioner and borrowed it from you.
Then, three days later , called you up to ask what the difference was between volts and ohms ?
Then too, do also remenber the time, unbeknowingst to you, that your brother in law , Casper Pee Clodd , came by and your wife found your meter for him.
Then that afternoon, when you get home you get this call from him, asking what the expected voltage from his cars ignition plug wire should be ?
Now I ask you , have you checked out your meter lately, using a 10Ω-100Ω -1KΩ -10kΩ-100kΩ-1megΩ set of test resistors ? (###)
As well as my mention of a DC voltage check with a 1.5 V dry cell and the 9V battery.
Then do a series check of that nine volt battery passing thru a 100 ohm resistor and the metering of the resultant DC current ,
And a final AC mode check, by the measuring of your AC line voltage .
Only then . . . . . will you know if any of those prior knaves hath done a DASTARDLY deed unto your FINE instrumentation.
Some how, even with your erroneous readout of the Easy80's tube, I feel that you should now get in a dark (bathroom?)** and plug it in and
then observe all of those little glow worms and see if their filaments are ALL making ORANGE for you.
** SAFETY CAVEAT:
Steer clear and stay away from touching any plumbing, even though that set is a transformer model and not an AC/DC model.
Thasssit . . .
(###) Ohhhhhh ! ! ! . . .Ohhhhhhh ! ! ! Ohhhhhh ! ! ! Edd "lak's" the on page convenience/access to those little ohmmie thingies, and not having to take, an otherwise
l o o o o ng circuitous path of having to shift to Symbols Font Cap W.
73's de Edd
