Radio to mp3 player conversion.
Discussion in 'Audio' started by Pexy, Jun 4, 2018.
  1. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    Greetings!
    I found a old Philips radio in the basement and would like to turn it into a mp3 player.
    My problem is that I don't know where to tap the input.
    The chip used in the radio is LA4160. there's a schematic in the datasheet and i tried in a few points but with zero success.
    Please help.
    Thanks.
  2. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    At the volume control is the usual place.
    Apply your input directly across it - might need a capacitor to block DC, depends on the schematic. Can you post it?
  3. Harald Kapp
    10,025
    2,138
    The datasheet shows the input of the LA4160 to be pin 9. Input your audio signal via a series resistor or attenuator on that pin.
  4. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    Pin 9 is through the pre-amp. The MP3 device is likely to not require pre-amplification and the main amplifier input is via pin 4. Plus it's easier to find the volume control!
  5. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    I will try it thanks.
  6. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    I tried the point that was conected to the pin 9(10) and it didn't work. I will try it directly at pin 9 with resistor as you said.
  7. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    thanks I will try it at volume control and pin 4 as well thanks.
  8. Harald Kapp
    10,025
    2,138
    Good point.
  9. ramussons
    ramussons
    356
    66
    Jun 10, 2014
    Hmmmm..... Is the radio working at all? At least some noise in the speaker....:confused:
  10. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    Yes it is. Radio side of things at least. Cassette mechanical part not but audio part works.
