Radio Reciever Circuit
Discussion in 'General Electronics Discussion' started by cjdelphi, Jan 25, 2016.
  1. cjdelphi
    cjdelphi
    1,161
    108
    Oct 26, 2011
    Hmmmm, i came across a circuit, i'd like to build it with my daughter, no problem, i thought i'd build it with components i already have..
    Ic1 = 4007???????
    Can't be, i'm thinking of a substitute, lm386 or a couple of dual opamps to get the 4th amplified state...
    Although, i think a 2 stage amplifier will be enough anyway...
  2. cjdelphi
    cjdelphi
    1,161
    108
    Oct 26, 2011
    Better image of the circuit, it's a 12yr old electronics book!
  3. davenn
    davenn Moderator
    13,984
    2,015
    there are dozens of crystal set radios with LM386 audio amp circuits on google
    and a hell of a lot easier to build that that circuit above
  4. cjdelphi
    cjdelphi
    1,161
    108
    Oct 26, 2011
    Yeah it is, but not really the point...
    4007ic was it used? I thought it was an inverter ic (not opamp)
  5. Colin Mitchell
    Colin Mitchell
    1,416
    314
    Aug 31, 2014
    It's just a junk circuit with almost not output.
  6. BobK
    7,682
    1,689
    It is an inverter. It is being biased into the linear region by the feedback resistor. Similar to the first stage, which is a transistor with a resistor from the collector to the base.
  7. AnalogKid
    AnalogKid
    2,621
    758
    Jun 10, 2015
    Fortunately, not every circuit that isn't oh-my-god-wowzer is junk. Something well known in the 70's but mostly lost today is that first generation CMOS gates, called unbuffered, were the original CMOS amplifiers. An unbuffered CMOS inverter is a high gain, not-all-that-great-bandwidth, above average crossover distortion, inverting amplifier.that naturally settles in at something near Vcc/2.
    ak
