M
markp
I am currently looking at a design that involves a very low cost radio based
'pseudo' network of devices that can be up to 2km apart.
Basically the requirement involves having up to 64 battery powered devices,
and a central controller. The controller must be able to address and send
data to each device individually or via broadcast, and the devices must also
be able to send data back to the controller when they need to. There is no
need for the devices themselves to inter-communicate.
The solution I'm currently looking at involves a time division multiplexed
radio link using one single channel. Timeslots are used to prevent
transmitters on each device from interfering with each other at the
controller's receiver, as they could all possibly want to communicate at the
same time, and the controller also has a timeslot for transmission so it
does not get interfered with either.
The requirement is complicated somewhat by the devices being battery
powered, and therefore cannot keep their receivers powered up continuosly
due to excessive power consumption. It's therefore important to be able to
power-down and power-up both transmitter and receiver sections of the
transceiver quickly. I also have the problem of synchronisation which I
believe can be done using this system.
Price is also real issue here, the transceiver must be as cheap as possible
(preferably < £10 each), and use a harmonised band such as 433MHz or 868MHz.
Can anyone suggest a very cheap solution to this?
Thanks!
Mark.
Thanks!
Mark.
