Radio Intermediate Frequencies
James Douglas
I am looking for a schematic that I can build that will teach me about
intermediate frequencies and radio reception. I want to be able to
simulate the circuit in CircuitMaker then build it and test it.
I am building/learning about radio reception and am not going to
continue building the radio without a through understanding of how
these intermediate frequencies work.
Thanks!
T
Tim Wescott
Thanks!
I'm not sure that any general-purpose circuit simulator will be up to
helping you much with superheterodyne radio design. AFAIK you pretty
much have to use mathematics, red in tooth and claw, to analyze the
performance if the thing. Fortunately the math doesn't have to be that
hard.
I suggest you look up the Amateur Radio Relay League (ARRL). Their
"Handbook" has many many basics including (probably) a superhet receiver
if not two or three. Also look at "Experimental Methods in RF Design"
by Hayward et all, and "Introduction to Radio Frequency Design" by
Hayward. I have the latter, and I've seen good recommendations for the
former.
On to your problem. Since it isn't clear about what you don't
understand it's hard to recommend a circuit. Let me give you this
thumbnail explanation, and you tell me where things are unclear:
The principal of the superheterodyne radio (i.e. one that uses an
intermediate frequency) is this: it is relatively easy to build a good
radio as long as all of the finely tuned circuits have fixed tuning, and
it is relatively easy to build a gizmo that takes a radio frequency
signal and shifts all of it's content by a fixed frequency offset. So
you build a really good fixed frequency radio and a really good
frequency shifter, stick them together, and voila! a good radio.
The fixed-frequency radio part is called the 'IF strip', and the
frequency at which it operates is the 'intermediate frequency (IF)'.
The frequency-shifting part is called the 'front end*' or the 'mixer' or
(in older material) the 'first detector'. It's frequency is set by the
variable frequency oscillator (VFO) if the radio is tunable.
* Purists: Yes, the mixer is just part of the front end, at least in
many radios. This is a basic, educational post. Go away.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
A
Anthony Fremont
This stuff has been beaten to death lately, but here goes. ;-) Since
all RF circuits are, by nature, sensitive to variations in frequency,
radios tend to use an IF (intermediate frequency) for achieving good
sensitivity, linearity and selectivity. The IF is usually chosen to be
the "difference" between the desired incoming signal and the LO (local
oscillator).
In most portable AM type receivers, the IF is chosen to be 455kHz. That
means in order to receive 545kHz thru 1650kHz, the LO must be able to
tune a range of 1000kHz thru 2105kHz. The LO is "mixed" (technically
this is a multiplication process even though it doesn't seem that way)
with the incoming signal. This process produces four output frequencies
(the two originals, the sum and the difference).
For example if we're trying to receive a station on 1000kHz, the LO
would be tuned to 1455kHz. This would produce a mixer output containing
signals on 455kHz (the difference), 2455kHz (the sum),1000kHz and
1455kHz. At this point the signal is passed thru a low pass filter to
remove everything above about 500kHz, a relatively simple process at
these frequencies. Then the signal is fed to an amplifier stage(s) that
are designed to work best at exactly 455kHz. Then this signal is passed
thru a diode (detector) and another low pass stage to remove the RF and
leave only the audio signal.
This is a simple description that only scratches the surface of the
theory behind all of it. There are technical reasons to pick specific
IF frequencies and to even have multiple IFs in a radio. Still other
times you may want the ultimate in simplicity and choose not to have an
IF at all. Google must surely be filled with pointers to information on
this.
A
Anthony Fremont
Geez, and you didn't even mention the preselector. (;-)
C
CWatters
Building and simulating may not be the best way to learn about this. Google
for articles on the Superhet principle.
Figure out why this equation is important..
sin(x) sin(y) = 0.5 cos(x ? y) ? 0.5 cos(x + y),.
R
RST Engineering \(jw\)
The hell you say?
Jim
I want to light a torch bulb from a battery source.
The torch bulb specification is it is the smallest one found in the
market.A MES is good enough.
I do not know of any other power sources so I am thinking of a pencil
battery. But I would prefer any LIGHT WIEGHT power source. Cost is not
any factor but the whoile system should be light weight. I would like
to build a car that have head lights and so is all this. My car is 7
inch in length. and should be very light wieght again!
Thanks.
Masroor.
G
Guest
: I am looking for a schematic that I can build that will teach me about
: intermediate frequencies and radio reception. I want to be able to
: simulate the circuit in CircuitMaker then build it and test it.
: I am building/learning about radio reception and am not going to
: continue building the radio without a through understanding of how
: these intermediate frequencies work.
James,
Find a diagram of a superheterodyne receiver. I'm sure you might
find one by just doing a google search for "superheterodyne receiver." It
will help you follow along with what I am saying.
I don't have time to post a detailed explanation, but in a
nutshell, the IF is a free parameter in a (super)heterodyne receiver that
is chosen to trade off the first stage filter "Q" or bandwidth/sharpness
with second stage filter/amplifier bandwidth/complexity.
The higher the IF, the the lower the Q of the first stage filter.
Choosing a higher IF may allow for the use of less expensive first stage
(RF) filters (Lower Q generally = Lower cost,) although these days, it's
more common to see lower or even 0 IF (also called direct conversion)
receivers.
The lower the IF, the lower the band of interest of the components
of the second stage (filter, amplifier, mixer.) Choosing a low IF may
allow for the integration of the IF filter in an IC receiver (which is
what I am most familiar with) or using a cheaper external filter (crystal
vs. SAW, etc)
So, in a general sense, you can think of the choice of IF as a way
of trading off first vs. second stage complexity. For lots of types of
receivers (FM, TV, etc) there exists a "customary" IF around which lots of
ICs (which may implement an entire second stage of an FM receiver, for
instance) have already been designed. Therefore, you don't see the IF
being changed in those types of receivers, although it can be.
That's the general idea...
Joe
It generates double side band, local to receiver.
By the way, why is it important mixing to get intermediate freq instead
of detecting audio directly from RF?
James Douglas
Thanks!
Thanks for all the great information! I will be reviewing everything
today as I'm sitting home with a sick kid.
I was hoping that I could simulate a circuit with two input frequencies,
for example 1Khz and 5Khz and somehow view/measure the output to be
XKhz? I will continue to research the superhet type devices. I do have
that AARL book around here somewhere.
A
Anthony Fremont
Well? I'm guessing that I've made some horrible error. Perhaps it's a
band-pass filter?
L
Le Chaud Lapin
Better yet, go for broke. Pretend that the whole world is made of
nothing but complex numbers. In other words, pretend that complex
numbers are not a special case of regular numbers that we learned in
grade school, but the end-all in general of quantities, and that it is
we, the humans, who have been operating in a mode of deficiency since
the very first time we learned to count.
Then you can assert that all functions are complex, where every part
that make them up is potentially complex. Then, for a wide variety of
functions, it is true that those functions can be represented as sums
of complex exponentials on t:
x(t) =Sum {-infinity, +infinity} (complex coefficient)*e-to-j-omega-t.
It would do you great benefit to take random "grade-school" functional
patterns of t that you make up yourself (sines, cosines, ramps, boxes),
and see if you an represent the functions as a sum of clumps where each
clump is a complex co-factor applied to e raised to j omega t. Keep
figeting with the per-omega clumps to get the signal to look right in
the time domain. This is most likely what Fourier did before he
arrived at his convictions.
If you view the world this way, as if all numbers were complex,
including the number of pieces of fruit that you last bought at the
supermarket, you will feel a lot better about all of this, because
there will be no more special cases, as everything will be complex, and
the vast majority of quantities that we experience each day, the
complex part just happens to be zero.
Then take the two pure sinusoids that you plan to mix, use Euler's
Theorem to treat them as two complex functions as above.
Multiplying them together (heterodyning) will quickly reveal, by
definition of multiplication of *any* two exponential functions (add
the exponents), that the frequencies will add in the resulting signal.
Then if you take a x1 to be sum of two sinusoids, and x2 to also be sum
of two sinusoids, and multiply them, you can see the blobs that they
make in the frequency domain (again by adding).
If you keep adding sinusoids to x1 and x2 so that they become "rich" in
time (and therefore spectral pattern becomes less spike-like), you will
see that the multiplication in time domain results in convolution in
frequency domain.
-Le Chaud Lapin-
C
CWatters
oops where did all the ? marks come from.
Well I guess you are all clever enough to know what I meant.
R
The normal coupling out of a mixer is with an RF transformer tuned to the IF
frequency. Let's see why a lowpass filter isn't of much use using your
example of a 1000kHz signal, a 1455kHz local oscillator, and 455kHz. IF
frequency. Let's go still further and postulate a 2-pole LPF which can be
made about the same size as that IF transformer. Put the cutoff right at
500 kHz. so that we don't lose a lot of the 455kHz. energy.
What's the attenuation at the signal frequency? Well, the slope of a
2-section RC filter is 12 dB per octave, and that is exactly an octave, so
you reject 12 dB of the unwanted signal frequency. 1455 isn't much above
that, so you lose perhaps another couple of dB. Big deal. When dealing in
an environment that has to handle microvolts to millivolts, 15 dB or so is a
drop in the bucket.
However, with an IF transformer, you will be down something on the order of
50 to 60 dB at the signal and about the same at the LO. Now we're talking
some decent attenuation.
Jim
T
Tim Wescott
The basic process of detecting audio (or data) from RF involves
filtering the RF, then detecting it as if the signal of interest were
the only thing there. That filtering step gets extremely complicated if
you try to make it tunable to any old RF frequency. By translating the
signal to match a fixed frequency filter-and-detect strip (the IF strip)
you simplify the radio design.
Tim Wescott
Z
Zak
XKhz?
You can: you will see an output consisting of 4 and 6 KHz tones.
Mix, say, 4 and 5 KHz and you will get 1 and 9. Filter that and you are
left with 1 KHz. Then, vary one of the frequencies and see what happens.
Or apply 4 and 4.5 on one input and5 on the other of the mixer, and
check what happens.
Excellent books. You need to get a feel for how this works - once you
graps it all kinds of things become possible.
Thomas
D
Don Bowey
I believe a Direct Conversion design, which eliminates the need for an IF,
makes separating the modulation from the RF signal quite simple. Direct
Conversion uses demodulation rather than envelope detection, so the signal
is baseband audio straight out of the mixer. A simple low pass filter (RC)
will prevent RF from affecting the following audio stage(s). If one wishes,
wideband and narrowband audio filters can be switched in/out for "music" and
CW.
Don
James Douglas
Thanks!
Damm, you guy's are either really smart or good bullshitters, I am
thinking smart. I appreciate all the help and now am armed with new
information to continue my experimentation.
S
Spehro Pefhany
<snip>
They are not necessarily mutually exclusive characteristics.
Best regards,
Spehro Pefhany
