R
Roy L
I have been fortunate enough to aquire these items and I am looking to
restore them. A plastic pushbutton is missing from the preamp and the
aluminium control knobs have a light corrosion on them. Should I
attempt to clean these off? Also the amplifier has a valve missing.
The one in the other channel in the equivalent position is an EF86, is
it safe to assume that this is the same type?
The label on the back is slightly damaged - I can see STA25 but the
top right corner is missing. I understand that there were a few
different MK's of this amp, is there any way of identifying which one
this is?
Valve line-up is as follows:-
Rear of amp
GZ34
EL34 Transformers in EL34
EL34 Screening Box EL34
ECF84 ECF82
?MISSING? EF86
Front of Amp
Any other advice/help with this amp would be much appreciated. I
suspect that it has not been used for quite a few years!
TIA Roy
this is?
Rear of amp
GZ34
ECF84 ECF82
?MISSING? EF86
Front of Amp
TIA Roy
