R.F filter for telephone
Discussion in 'General Electronics Discussion' started by tzitzikas, Sep 26, 2010.
  1. tzitzikas
    tzitzikas
    16
    May 9, 2010
    hi i am radio amateur at 160m. the problem is that when i operate my transmitter the transmitter create interference to the telephone.
    i am thinking to put a circuit at telephon's line. My first thought is to put capacitors (10nf) which will ground the r.f. signal what do you think about this. Do you have any better proposition? some one tell me to put one adsl filter.
  2. Militoy
    Militoy
    180
    Aug 24, 2010
    The cap will probably help - Center frequency on 160m is 1.9 MHz - so the reactance of a 10nF cap at that f would be 8.38 ohms - enough to damp a 600 ohm line of RFI fairly well. You might consider building a full trap though - adding a parallel inductor to sharply notch out interference throughout the full 160m band.
  3. davenn
    davenn Moderator
    13,798
    1,939
    You may even find 2-3 turns of the phone cable through a clamp-on ferrite core
    will do the trick. place the core on the cable right where it enters the phone
    cheers
