M
MassiveProng
She's an idiot!Don't. You'd be lunch.
perhaps you should have read the two links.
Once again, the mighty ass has opened his mouth to roar, but merely
drooled down his chest, instead.
Ok - how do we send 100,000 volts to Homer's PC?
But my logical skills are infinitely superior to yours.
You may be a pussy who will let two dicks like Jim and John insult you. I am
not.
Nope. You haven't been paying attention so who is retarded? I actually have
two separate trade qualifications, some advanced trade qualifications, a
degree and considerable experience in a number of strange technical or
related fields.
Jim said:Jim Thompson wrote:
[snip]
So ask a technically useful question already ;-)
...Jim Thompson
OK,
Im playing with an el-cheapo smps controller. Its peak-current-mode
control, and uses the BE junction of an NPN to detect peak current, and
turn the switch off. Of course Vbe varies strongly with T.
Normally I use a TL431 etc for voltage feedback; it has a nice stable
reference. I just choose my current sense resistor for min Vbe (max T),
and the magic of -ve feedback makes sure all is well. yay.
the circuit is pretty simple, the 431 pulls down on a pnp (crappy
mirror) which feeds current into an R, also connected to the base (there
is an R from B to Rs) so the base voltage is the sum of IRs and the
error amp output voltage.
This time, however, I want to use it as a current regulator. There is
still a setpoint, but no error amp (other than the NPN), so alas all my
-ve feedback "magic" stops working, so I have to:
a) temp-comp the setpoint (or NPN, but I want to keep I*Rs low), or
b) add some other form of current sensor, a T-stable reference and an
error amp, which I dont want to do.
so far the best I have come up with is placing a Vbe multiplier (using
the other transistor in the NPN's sot-323 package) in series with my
setpoint voltage. If I choose the Vbe multiplier scale factor to be the
reciprocal of the resistive divider formed from Vsetpoint to Rs, then
the divided-down scaled-up Vbe temperature change exactly (ish) cancels
out the dVbe of the NPN.
kinda:
Vsetpoint----[Vbe multiplier]---[R1]----+-----B of CE NPN
0V--[Rs]--+---------------------[R2]----+ 0V
to switch Source (or E)
R1,R2 >> Rs
so I get:
Vbe1 - dVbe1 = (I*Rs)*R1/(R1+R2) + (Vs - K*(Vbe2 - dVbe2))*R2/(R1+R2)
and if the 2 BJTs are at the same temperature, then dVbe1 = dVbe2
so all I have to do is choose K = (R1+R2)/R1.
but it feels kinda icky.
Cheers
Terry
Can you post a schematic? I don't understand words very well ;-)
...Jim Thompson
Then why do you never make technical contributions to the group?
What are these trade qualifications and degree?
[snip]
...Jim Thompson
OK,
kinda:
R1,R2 >> Rs
so I get:
Cheers
Terry
...Jim Thompson
Not really, I dont have access to ABSE. But I did send you an email.
Terry
MassiveProng said:At least it hits his chest. Yours runs down your leg.
Stop talking out of your ass, boy.
Bwuahahahahaha!
Homer said:Says who? You're the one who likes to start pissing contests.
Like I'd tell you.
the ESTx were done solely so I am legally able to mess with electrickery,
instead of having to pay for a sparky.
And I learned a good trick, which is to make the earth wire in a plug
1-2cm longer than all the rest, so its the last one to come out when
yanking on the cord.
I did, dumbfuck. You didn't.
BOTH have "to make certain" in then.
One, as the first given definition, and the other, a bit farther down.
Try again, gloss over boy.
Homer said:I'm a sparky in two countries and plan to add a third.
If you've anchored the cord right it won't come out.
The best trick is to remember our motto: "One flash and you're ash!"
Absolutely not.
Yes there damn well is !
Yes he did !
There's a reason that insurance policies aren't called ensurance policies. One
is simply a financial matter, the other would need the company to be a God.
Oh right. So that makes them identical in meaning does it ?
So how much do you pay for your car ensurance ?
I don't suppose you understand the difference between alternate and alternative
either ?
Graham
MassiveProng said:The ALTERNATIVE to you understanding this issue is for me to ignore
you for your utter stupidity.
One does not get ensured. Yeah, dumbfuck, I know that.
BUT, one can say "Ensure that you handle this problem."
Correct.
AS WELL AS "Insure that you handle this problem."
As well as: "Assure that you handle this problem."
In THAT context, either is correct, as well as the third.
Ever ?
