Quine McCluskey optimization program
Discussion in 'Microcontrollers, Programming and IoT' started by gvoland, Apr 25, 2020.
  1. gvoland
    gvoland
    Apr 25, 2020
    I am also new here and would like to share a program with you.
    It is called QMC2 in the version 1.4 and performs optimization/minimization of boolean logic by using the Quine-McCluskey and related algorithms.
    It is a Windows 10 program and comes with a Help file and numerous Examples.
    The logic description can be provided in several different formats as tables or as boolean expressions.
    The execution flow is displayed and can be followed on an ASCII work area.
    The degree of display can be set from minimum to very detailed reporting on every step - good for educational purposes. The reports are stored as ASCII text files and in RichText format.
    The parts of the zip file are: QMC2.exe, QMC2_Help.pdf and a directory with Examples.
    Download QMC2_V1.4.zip at own risk.
    Regards
