D
davidlaska
I am not sure what a LCD projector is but there is a booklet onJames said:I don't have a meter to check the brightness output, but it is more then
enough to replace the lamp in an lcd projector. I did a small board of 96
led's running on a 12 volt NiCad battery pack and took it outside at night,
just to see how it stood up to a flashlight. That small panel would light
the trees across the street from my house. The light it makes also seems to
make everything in high contrast. Give it a try and you will see what I mean
by that.
As far as wattage, (350 strings drawing .025 ma.) = 8.75 amp = (12v * 8.75
amp) = 105 watt on the panel. But you can judge the led brightness by that,
as Led's are more efficient then Incandescent lamps.
The angle on the led's were 20 degree if I remember correctly
building you own home entertainment theater where a LCD is projected to
the screen with a those outdoors Sodium light 400 watts ( last for ever
to).
