Quick dB question
Discussion in 'Electronic Basics' started by Grey, Sep 5, 2004.
  1. Grey
    Grey Guest
    How do I calculatre if I have a 30v signal and I reduce it by -6dB?
    Graham
  2. John Miller
    John Miller Guest
    To reduce it by -6 dB, multiply times four. (Although you probably intended
    to reduce it by 6 dB, which would mean dividing by four.)
    John Miller
    Email address: domain, n4vu.com; username, jsm
    Punishment becomes ineffective after a certain point. Men become
    insensitive.
    -Eneg, "Patterns of Force", stardate 2534.7
  3. Dbowey
    Dbowey Guest
    Grey posted:
    << How do I calculatre if I have a 30v signal and I reduce it by -6dB? >>
    You will have a 15V signal after you do that.
    dB= 20*log E1/E2.
    Don
  4. Graham Knott
    Graham Knott Guest
  5. Gareth
    Gareth Guest
    That is, of course, you divide the POWER by four. The voltage will be
    reduced by a factor of two since power is proportional to voltage squared.
    Gareth.
  6. John Miller
    John Miller Guest
    Yes, exactly right. I shouldn't post before waking up.
    John Miller
    I was the best I ever had.
    -Woody Allen
  7. Jamie
    Jamie Guest
    lets see if my math will pop to my head.
    (20 * log(30))-6 = 15 DB
    of course you can put that back into the V signal after.
    V = InvertLog(15/20) = 5.6; etc///////////////
    which should give you something to work with..
    to the best of my knowledge that should be close
    enough.
  8. john jardine
    john jardine Guest
    You need to find what "-6dB" means in a real world so ...
    Divide "-6" by the magic number of "20"
    Get "-0.3"
    Find the antilog of "-0.3" (ie press the 10^x button)
    Get "0.501187"
    This is how much the 30V needs reducing.
    So ... 30V X .501187 = 15.035V
    This works for volts and amps. People normally just regard the -6dB as "a
    half" or "+6dB" as "2 times".
    regards
    john
  9. JeffM
    JeffM Guest
    Professor: Two negatives give a positive result,
    but two positives don't result in a negative.
    Voice from back of classroom: Yeah, right.
  10. Tim Auton
    Tim Auton Guest
    That's a (mis) quote of the late Sidney Morgenbesser. OK, perhaps he
    wasn't the only person to say it, but he's arguably the most famous.
    "The most celebrated Morgenbesser anecdote involved visiting Oxford
    philosopher J. L. Austin, who noted that it was peculiar that although
    there are many languages in which a double negative makes a positive,
    no example existed where two positives expressed a negative. In a
    dismissive voice, Morgenbesser replied from the audience, "Yeah,
    yeah..."
    (from the New York Sun website, but it's elsewhere too)
    Tim
