questions silica gel old
Discussion in 'General Electronics Discussion' started by gamer87, May 12, 2019.
  1. gamer87
    gamer87
    166
    Mar 11, 2017
    Is it dangerous to store an electronics with silica gel sachets for many years? will the silica gel crack cracking and release all stored water and moisture and damage device electronic? silige gel absorbs moisture
  2. duke37
    duke37
    5,268
    728
    Jan 9, 2011
    The moisture is absorbed in the gel structure so will not leak out. The moisture is liberated if the gel is heated so the sachets can be dried in an oven.
    gamer87 and davenn like this.
  3. gamer87
    gamer87
    166
    Mar 11, 2017
    the silica gel ages over the years, when the gel gets old streak and releases the water?
  4. Harald Kapp
    9,502
    1,957
    Usually not.
    davenn likes this.
  5. gamer87
    gamer87
    166
    Mar 11, 2017
    Is not there such a risk and concern? if she releases the water she becomes corrosive
  6. Harald Kapp
    9,502
    1,957
    See the last item in this list.
    gamer87 likes this.
  7. gamer87
    gamer87
    166
    Mar 11, 2017
    In this faq, you do not have the answer to my doubt. the blue silica gel can be reused how many times?
  8. duke37
    duke37
    5,268
    728
    Jan 9, 2011
    If you look on Wikipedia you will see that the blue silica gel contains a cobalt salt which is not heathy so do not eat it. The colour will tell if the gel is saturated with water.
    You could experiment to determine the number of useable cycles. My guess would be about a thousand.
  9. Harald Kapp
    9,502
    1,957
    I'm sorry, I copied the wrong link (although it was part of the search list). The correct link is here.
