Questions Metal Speakers
Discussion in 'Audio' started by gamer87, Jul 4, 2019.
  1. gamer87
    gamer87
    166
    Mar 11, 2017
    CRT TV speakers and screws do you have any protection so that the acid from your hands does not start corrosion?
  2. davenn
    davenn Moderator
    13,397
    1,790
    rubber gloves ... like surgical gloves, they are readily available
    but seriously, it isn't really an issue .... keep you hands dry with a towel
    gamer87 likes this.
  3. Martaine2005
    Martaine2005
    2,514
    671
    May 12, 2015
    Use vaseline as a grease.
    Or use gloves to avoid starting corrosion!
    Martin
    gamer87 likes this.
  4. davenn
    davenn Moderator
    13,397
    1,790
    thanks for the backup ;) ;)
    gamer87 likes this.
  5. Martaine2005
    Martaine2005
    2,514
    671
    May 12, 2015
    you beat me to it!!..we were typing at the same time.
    Martin
    davenn and gamer87 like this.
  6. gamer87
    gamer87
    166
    Mar 11, 2017
    I always wash my hands before touching the metal but I do not wear gloves
    Is it a serious problem?
  7. Martaine2005
    Martaine2005
    2,514
    671
    May 12, 2015
    The oils from your hands and or the air around your equipment can cause corrosion.
    Use surgical gloves as already mentioned by @davenn .
    1980s gear is already violated by air,sea and air. These affects cannot be stopped. It's called old aged..
    Martin
  8. gamer87
    gamer87
    166
    Mar 11, 2017
    Does the metal structure of the speakers have no protective varnish of the oil of the hands?
  9. Martaine2005
    Martaine2005
    2,514
    671
    May 12, 2015
    No, not years ago. Today, most equipment is sprayed with a varnish type substance.
  10. dave9
    dave9
    830
    200
    Mar 5, 2017
    Not really relevant, the metal frame on an internal speaker is not exposed to view for the life of the TV/etc equipment. Any cosmetic blemish from touching it with bare hands, will not significantly affect its performance or lifespan.
    If you were instead doing mass production in a factory, sure, wear white gloves and change them out when soiled. You'd probably want something breathable for long term use since latex, nitrile, etc will trap moisture and be hard on your hands, and may not wear long since the sharp edges on stamped steel speaker housings will tend to wear holes in them.
  11. gamer87
    gamer87
    166
    Mar 11, 2017
    Touching the metal in the dehumidifier will not increase acid corrosion. The biggest concern is with moisture?
    Does using the appliance regularly 1x a month prevent moisture from accumulating and accelerating oxidation points?
  12. davenn
    davenn Moderator
    13,397
    1,790
    As I said way back in post #2, it's really not a problem
  13. gamer87
    gamer87
    166
    Mar 11, 2017
    Is the speaker metal varnished? touch the metal with your hands the nail polish protects?
    [​IMG]
  14. davenn
    davenn Moderator
    13,397
    1,790
    no, that metal isn't varnished, but it is plated
    Again, you are stressing/panicking about nothing
  15. Martaine2005
    Martaine2005
    2,514
    671
    May 12, 2015
    All I can say is..
    Try and not wear nail varnish when handling metal speakers. You may scratch them.
    Martin
