Questions lithium polymer battery
Discussion in 'Power Electronics' started by gamer87, Jan 10, 2020.
Thread Status:
Not open for further replies.
  1. bertus
    bertus Moderator
    534
    178
    Nov 8, 2019
    Hello,
    Did you read this on the page I gave you:
    Bertus
  2. gamer87
    gamer87
    203
    Mar 11, 2017
    I want maximum battery life according to my conditions and recharge every 3 months in the manual does not say 100% recharge
    are 3 bars status battery lcd plasma pen
  3. Audioguru
    Audioguru
    2,788
    633
    Sep 24, 2016
    We do not know how much of a charge is there when 3 or 4 bars are shown.
    We do not know if your charger properly detects a full charge (not simply showing the voltage) then stops charging.
  4. gamer87
    gamer87
    203
    Mar 11, 2017
    If you look at the photo you can see that the indicator has a total of 3 bars so 3 bars are 100% and I only have to recharge 2 bars to avoid going 100% and jeopardizing the useful life of the polymer lithium battery? recharge for USB cable
  5. Audioguru
    Audioguru
    2,788
    633
    Sep 24, 2016
    We do not know what the bars show. If 3 bars is fully charged then we do not know what 2 bars is. 2 bars might be when the battery is close to the 3.2V warning or the 3V minimum allowed.
    Charge it to 100% then remove the battery and let it sit for one hour then measure its voltage.
    Then install the battery and use it until the display shows 2 bars, remove the battery, let it sit for 1 hour and measure the voltage.
    Report the voltage measurements here.
  6. gamer87
    gamer87
    203
    Mar 11, 2017
    I have no way to measure the battery because it is very difficult to remove the lithium polymer battery from the device it does not have screws what I have is this charge status indicator with 3 bars indicating full charge
  7. Alec_t
    Alec_t
    2,787
    742
    Jul 7, 2015
    a) Charge it to 2 bars.
    b) Wait 2 months.
    c) If the charge state is 0 or1 bars then charge to 2 bars.
    d) Repeat b and c indefinitely.
    Report back in 2 years time.
  8. gamer87
    gamer87
    203
    Mar 11, 2017
    if i recharge 3 bars is it sure it is the same as 100%? I'm in doubt because the manual says to recharge every 3 months
  9. Audioguru
    Audioguru
    2,788
    633
    Sep 24, 2016
    Nobody knows what the bars mean.
    Nobody knows why they say to recharge every 3 months.
  10. gamer87
    gamer87
    203
    Mar 11, 2017
    recharging every 3 months is correct or wrong?
  11. Bluejets
    Bluejets
    3,976
    820
    Oct 5, 2014
    This is going absolutely nowhere ....advice you've been given seems to be ignored.
    Alec_t likes this.
  12. gamer87
    gamer87
    203
    Mar 11, 2017
    If during the use of the device the charge reaches 0% or close to 0% the useful life of the lithium polymer battery is reduced or the useful life is reduced only if it stays at 0 or close to many days?
    if I recharge the lithium polymer battery to 100% and use the device, will the useful life be reduced or will the useful life of the lithium polymer battery only be reduced if I store many days by 100%?
  13. Audioguru
    Audioguru
    2,788
    633
    Sep 24, 2016
    www.batteryuniversity.com answers most of your questions about a lithium rechargeable battery but they don't know the product's charger or anything in the product (a clock?) that is draining the battery for 3 months.
    They say that if a Lithium cell's voltage has stayed long at a full charge voltage of 4.20V then its life is shortened. They say that if it is discharged below about 2.5V or 3V then it is ruined.
    They say that if you do not use it for any amount of time then the battery will last longer if it is stored at 3.7V to 3.8V.
    The battery also has a limit for the number of charge, use then recharge. About 500 times.
    My lithium rechargeable batteries are stored all winter at 3.7V then used about 100 times each summer. They last for 4 to 5 years.
    A friend of mine bought 10 Cheap Chinese lithium rechargeable batteries. 5 did not work and the others lasted only for a few times.
    Nobody knows what the bars on your product are showing.
  14. gamer87
    gamer87
    203
    Mar 11, 2017
    What do you recommend for my case of this device and that lithium polymer battery ??
  15. Alec_t
    Alec_t
    2,787
    742
    Jul 7, 2015
    That you stop posting the same request repeatedly.
    You have already received advice, which you have chosen to ignore.
  16. bertus
    bertus Moderator
    534
    178
    Nov 8, 2019
    Hello,
    Did you read post #61 with a copy of the page I gave you earlier?
    Bertus
  17. gamer87
    gamer87
    203
    Mar 11, 2017
    I did not ignore the advice, only I said what is included in the manual of the device and I want to adjust it for longer life of the lithium polymer battery because it is not possible to always measure the voltage and discharge
  18. bertus
    bertus Moderator
    534
    178
    Nov 8, 2019
    Hello,
    Does the pen give a warning when it needs to be charged?
    I have a toothbrush with a lithium battery that has an 3 bar indicator.
    When the battery is "empty" the lowest led wil blink red, as sign that it needs charging.
    (the leds are only on when in use).
    Bertus
  19. gamer87
    gamer87
    203
    Mar 11, 2017
    I do not know
  20. gamer87
    gamer87
    203
    Mar 11, 2017
    I received the equipment when turning it on, it was charge with 2 bars and I put it to recharge for 30 minutes after 30 minutes it was still on 2 bars so I put it to recharge for 1 hour
    Is it possible to extend the recharge and discharge cycles of the lithium polymer battery?
Thread Status:
