Questions conservation electronic
Status
Not open for further replies.
gamer87
Mar 11, 2017
261
Mar 11, 2017
261
If I get wet air inside the tied bag that I posted the photo will also enter dry air?
Is there any way to avoid moisture problems without using silica and no other items? Control in a natural way?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
You could vacuum seal the bags.
gamer87
Mar 11, 2017
261
Mar 11, 2017
261
Difficulty in removing and placing the electronics inside the vacuum
(*steve*)
25,510
25,510
Fill all the empty spaces with silica gel first then!
(*steve*)
25,510
25,510
Ziplock bag protects from moisture?
They might be ok if you squeeze most of the air out and include a silica gel pack to absorb any moisture in the contents.
gamer87
Mar 11, 2017
261
Mar 11, 2017
261
Is it more dangerous to humidity the use of a common tied bag or a ziplock bag?
(*steve*)
25,510
25,510
Neither is more dangerous to humidity
A sealed bag Mary be more dangerous to the contents if you don't take action to handle moisture that is trapped in the sealed bag.
A tired bag may be more dangerous to the contents if the air outside has lots of moisture.
gamer87
Mar 11, 2017
261
Mar 11, 2017
261
Which room or room is most recommended for storing electronics? Closed room without door and without window?
(*steve*)
25,510
25,510
That is pretty much impossible to say.
A room with controlled temperature and humidity would be best
gamer87
Mar 11, 2017
261
Mar 11, 2017
261
Is it possible to preserve an electronics without the use of silica gel desiccant?
Alec_t
Jul 7, 2015
3,590
Jul 7, 2015
3,590
Yes, if you keep the electronics in a vacuum or in a closed environment which has some other (e.g. mechanical) de-humidifer. Perhaps in a freezer?
(*steve*)
25,510
25,510
Since you keep asking the same question, perhaps we should ask what answer you want.
How about:
  1. Store them in paper bags with an old mushroom
  2. Soak them in olive oil and place them in a barrel of salt.
  3. Wrap them in cling-wrap and place them in a shoebox with a smelly sock.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
What is wrong with silica gel?
Store them in a sealed plastic box with a lid clipped shut. I store my rolled oats (for porridge) in such a box.
Put some well-dried grain in to absorb water from any leaking air, in other words use this as a substitute for silica gel. The grain (wheat, oats, maise, rice) can be dried in an oven.
What is your local climate?
What is wrong with slica gel?
Status
