Questions cable controls snes
Discussion in 'General Electronics Discussion' started by gamer87, Feb 3, 2020.
  1. gamer87
    gamer87
    186
    Mar 11, 2017
    the cables of my Snes controls are dry and stiff. is there a chemical product to return the cable flexibility?
  2. Kabelsalat
    Kabelsalat
    117
    22
    Jul 5, 2011
    No, unfortunately there isn't. And if it somehow existed such a substance, how should you get it applied into the whole volume of rubber and not just the surface ?
    davenn likes this.
  3. HarryA
    HarryA
    59
    17
    Jan 22, 2017
    Make a small loop in the cable and soak it in acetone as a test; works for me. Save the used acetone to clean paint brushes with.
  4. bertus
    bertus
    256
    82
    Nov 8, 2019
    Hello,
    The plasticizer has probably evaporated from the cable.
    Watch out with acetone.
    Acetone might dissolve the plastic.
    From the wiki:
    Solvent
    Acetone is a good solvent for many plastics and some synthetic fibers. It is used for thinning polyester resin, cleaning tools used with it, and dissolving two-part epoxies and superglue before they harden. It is used as one of the volatile components of some paints and varnishes. As a heavy-duty degreaser, it is useful in the preparation of metal prior to painting or soldering, and to remove rosin flux after soldering, which helps to prevent the rusty bolt effect.
    https://en.wikipedia.org/wiki/Acetone
    Bertus
  5. HarryA
    HarryA
    59
    17
    Jan 22, 2017
    Yes It may dissolve the plastic at the connectors. One can get cable extensions for 8$ and splice them in for new cables perhaps?
  6. dave9
    dave9
    843
    206
    Mar 5, 2017
    You could try an automotive vinyl/rubber conditioner product, but if it's vinyl and had significant UV (sun) exposure, it may eventually crack apart no matter what you do except to avoid flexing it much.
  7. gamer87
    gamer87
    186
    Mar 11, 2017
    Does this product recover the cable's flexibility?
    [​IMG]
  8. dave9
    dave9
    843
    206
    Mar 5, 2017
    lol, I'd try the vinyl conditioner first because once you put that on, nothing else is getting into the pores. That is more of a protectant than a conditioner.
  9. gamer87
    gamer87
    186
    Mar 11, 2017
    This vinyl conditioner product is difficult to find in Brazil is it very different from silicone gel? how is it working
  10. dave9
    dave9
    843
    206
    Mar 5, 2017
    I know nothing about Brazilian Auto Parts stores, but any with a good stock of products should have an entire wall devoted to cleaning and conditioning products. Amazon.com.br appears to have Mother's Vinyl & Rubber Care, perhaps other suitable products too. Normally a conditioner would have propylene glycol in addition to silica gel.
  11. Martaine2005
    Martaine2005
    2,538
    681
    May 12, 2015
    Ask @Ratch , he will be there soon. He can bring you big drums of the stuff.
    WARNING: Never mention tide movement times or current flow to him!
    Martin
    Harald Kapp likes this.
  12. gamer87
    gamer87
    186
    Mar 11, 2017
    could you recommend me good products and the necessary composition?
    were you able to recover dry rubber and plastic cables using this product? are they flexible again?
  13. dave9
    dave9
    843
    206
    Mar 5, 2017
    There is no forever. Follow best practices or don't but the worst thing to do is waste time while time still has its way...
  14. gamer87
    gamer87
    186
    Mar 11, 2017
  15. gamer87
    gamer87
    186
    Mar 11, 2017
