Questions about equivalents of audio/video and digital/analog.
Jerry Avins
Floyd said:
I'll admit to a really great fit of laughter at that one!
You are so thoroughly confused that it is hilarious.
The recognized standard definitions say that a quantized
signal is digital. You can indeed have a two-level
analog signal, but the fact is that the *possible*
values are infinite (all values between your two listed
ones, for example). You cannot possibly have a digital
signal with a continuous range of values (large or
small, relative or otherwise).
I've cited multiple credible sources that agree with
what I say. You can't cite even one. There are none.
There are only two possible values for the output of a hard limiter.
Make something of it. OTOH, bu using CMOS logic and varying the power
supply voltage randomly between the limits of 3 volts and 18 volts, I
can hive a digital signal an infinite number of values.
Jerry
F
Floyd L. Davidson
There are an infinite number of errors in your
statement.
An FM signal, such as you specified earlier, does not
encode information as voltage levels.
The phase or frequency contains the information, and a
hard limiter does not restrain the values to only two.
There might in fact be only two, but we don't know that
and the limiter does not assure that.
For a typical FM signal modulated by audio we might well
have an infinite number of possible values after the
signal is passed through a hard limiter. It is also
true that we could modulate it with something else that
has only two values, and then it would be digital.
That would be funny if you were joking, but Jerry I
realize that you are dead serious.
Lets use, just for this example, an RS-232C interface
definition. We could use some other interface, and it
would always be the same result. But since your voltage
range fits within the range of voltages that are correct
for RS-232 (and few others do) we'll use that.
If your signal varies between +3 and +18 volts, it has
exactly 1 value. That is a space signal. If you want
it to be mark, you can vary it between -3 and -18
volts...
Yes, you do have an infinite number of *voltages*
between 3 and 18, but only one signal value.
Tell me Jerry, do you actually get paid to do
engineering?
E
Eric Jacobsen
statement.
We all know that. You seem to be trying to catch up, though.
The example is of the sort of hard limiting achieved by something like
a Class-C amplifier where the limiter does limit the output values to
two voltages. This is a specific function in an important stage of a
common FM demodulator architecture. Jerry spelled this out pretty
clearly, but you're having a real hard time understanding the folks
here who know what they're talking about. Pay attention.
A limiter in this sense absolutely does assure that. The idea is to
remove any AM modulation, which is fine in an FM signal since there's
no information in the amplitude. Limiting it to two voltages helps
clean up a lot of noise and distortion with a relatively simple
implementation.
You're not following; the limiter limits it to two voltages. That's
what a limiter does in this case. It's a pretty common function,
with a very common symbol used frequently in block diagrams and
schematics. Jerry's question, which you've been dancing around
without any sort of coherent response that I can detect, is whether
the signal at the output of the limiter is digital or analog according
to you? The situations that you've been describing and explanations
for definitions that you claim to be absolute and universal don't seem
to work well for some of these cases.
It is also
LOL!
Okay, so we can modulate it FM with audio, and limit it, and then it's
two voltages, but it's not digital. But if we modulate with only two
values, then it's two voltages and it is digital! Right?
Floyd, you must have a mind for detail to be able to keep track of all
the goofy, byzantine distinctions you try to make up.
definition.
Why not just stick with the example Jerry gave? You have a digital
CMOS circuit, the high voltage is one, the low voltage is zero (or,
just to keep you comfortable, mark and space). Vary the supply
voltage, over some range, so that the voltages for one and zero (oh,
wait, mark and space) change. You could even stretch the example a
little bit so that the receiving CMOS gate supply voltage stays at the
same level, because there's a lot of slop built into these things. So
does it stop being a digital circuit because there is an infinite
range of voltages being used?
volts...
So, in your mind, is it digital or analog?
Eric Jacobsen
Minister of Algorithms
Abineau Communications
http://www.ericjacobsen.org
M
Mr.T
between 3 and 18,
Only in theory, in practice nothing is infinite in this universe.
Noise will set the resolution limit.
MrT.
F
Floyd L. Davidson
The noise itself has an infinite number of possible
values, and therefore even if the signal itself is
supposed to be just 1 value, add the noise and there are
G
glen herrmannsfeldt
Floyd said:
Jerry Avins <[email protected]> wrote:
(snip on analog vs. digital signals)
statement.
Previously when I was in these discussions instead of
digital vs. analog it was modulated (and so in need of
a modem) vs. not modulated. Passing a digital signal
through an analog channel is said to require a modulated
carrier. In that case, it is an analog representation
of a digital signal.
(snip)
OK, so when is it a direct representation of a digital
signal instead of an analog channel with a modulated
signal? I might believe it for NRZ, but just about
anything else I don't.
volts...
Say you have a space alien trying to decode the signal.
In this case, as with other NRZ signals, there are two choices:
The higher voltage represents '1', or the lower voltage.
There also needs to be a way to know when the value is there,
usually an external clock signal.
How about this for a digital signal: I take an analog telephone
and say into it either "one" or "zero". That is, the english words.
The information content is digital, but the representation is
pretty definitely analog.
-- glen
F
Floyd L. Davidson
Okay...
carrier.
That is not necessarily true. The problem has nothing
to with analog vs digital. It instead a question of
whether DC can be amplified or only AC, and over what
bandwidth, on that analog channel.
I'm not sure that makes sense for an electrical signal.
A digital representation of an analog signal does (the
result when restored is called quasi-analog though).
However, I do think that your last example, discussed
below, appears to be a valid example of an analog
representation of digital signal, except it is not an
electronic representation...
(snip)
Any time you encode discrete values from a finite set,
that is digital. Period. Whether it can be passed over
an inherently analog channel or not is fairly
meaningless. The voltage, phase, or whatever that is
encoded with the information may have only a discrete
set of values for the information, but they obviously
take on an infinite number of possible values for the
characteristic itself.
Hence the voltage on a binary system carries only two
values, on and off, but that is the value of the
information. The voltage that is encoded might be +3 to
+15 for an on and -3 to -15 for an off. And when the state
switch from on or off to the opposite value, those
voltages do not change instantly, and they do cover an
infinite number of voltages during that change.
That is an infinite number of possible voltages, but
they have a value of either on or off.
The information values are what makes it a digital signal.
But indeed, you can pass that signal through an analog
amplifier. Depending on the characteristics, it may or
may not destroy the information. Obviously the
amplifier would need to pass DC voltages unless we
encode the information in a way that guarantees some set
minimum time interval between state changes (T1 digital
carrier systems typically do that, for example).
If the digital signal has DC components it can be
modulated onto an analog carrier to pass through an AC
coupled analog channel. It could also be re-encoded
in a manner that will pass through an AC only channel,
and then be transmitted over the same AC coupled analog
channel.
Most physical channels are inherently analog! Wire
cables and fiber optic cables are two examples. Digital
signals are commonly sent via either of them.
Yes, but you aren't saying anything of significane to the
rest of the discussion.
This is even farther off track. (Not that it isn't
interesting! clock synchronization is a really
fascinating topic in my opinion.)
The information content encoded and sent electronically
is not digital. There is nothing digital about the
sound of your voice. And while "one" and "two" might be
digital, those are not the values that are encoded and
set over the telephone wires. It is the difference
between "one" and "uno" that is encoded, and that is an
infinite number of variations.
But, I do think you've stated a good case for the analog
representation of a digital signal! The "one/two" code
(like Paul Revere's message) is in fact digital, and it
is being sent over an analog channel, which is the
channel from your mouth to your ear!
G
glen herrmannsfeldt
(I wrote)
(snip)
When DSL started to become popular, there was discussion
that a DSL modem wasn't a modem because the DSL signal
was digital. Everyone (just about) knows that v.90 needs
a modem because it goes through the voice telephone system.
But DSL does use a modulated carrier, and the box is
a modem.
(snip)
But why phase modulation, for example? Two reasons
that I see. One is that the channel does not have
the appropriate frequency response, and the other is
the need for a clock. Consider 10baseT ethernet.
Phase modulation allows for transformer coupling that
is needed to avoid ground loops and ensure a balanced
signal to avoid EMI problems. Using synchronous
phase modulation allows for the recovery of the clock
from the signal, which is also important.
If, for example, the signal was not modulated and one
decided to send 1000000 zeros in a row, there would be
no way to recover the clock to know how many zeros
were sent. If you can't separate the bits, you are
losing an important part of a digital signal.
If the information is destroyed, then the signal
didn't get through.
Obviously the
channel.
Some can pass a digital signal without modulation,
others can't.
(snip)
-- glen
E
Eric Jacobsen
In that case, the quantum nature of matter means that *everything*
*everywhere* is digital. So no need to talk about this analog stuff
anymore.
Eric Jacobsen
I
isw
I'll probably regret jumping in here, but:
The *message* may be digital, but the *signals* are most definitely
analog.
Isaac
B
Bob Myers
analog.
The SIGNALS are electrical or optical.
Bob M.
F
Floyd L. Davidson
(snip)
Everyone who thinks that is wrong. A v.90 modem is
digital on both sides, and will not pass through a
"voice telephone system". It requires a *digital*
switching system to work. V.90 is not a D/A-A/D
protocol, it is a digital level encoding scheme.
(Indeed, a lot equipment originally used for 56Kbps
digital services was often called a "modem" by not just
customers, but also by telecommunications people. None
of them were technically modems, they were all level
changers, with digital signals in one side and out the
other in a different, but equally digital, format.)
a modem.
But is that because it has a digital side, or is that
because the bandwidth restrictions of the channel cannot
pass the input signal due to the low frequency
components?
It is a bandwidth problem, and it has nothing at all to
do with digital or analog.
In fact, a v.90 modem sends an entirely digital signal
down that very same line. Of course in the process it
necessarily uses the same bandwidth that on a DSL is
allocated for a normal voice channel, and therefore
while DSL can co-exist separately with POTS the v.90
modem cannot.
It has *nothing* do to with whether it is digital or
analog...
Two reasons
Phase modulation does not uniquely conserve bandwidth
(Manchester encoding uses twice the bandwidth of NRZ,
for example) nor is it unique in the ability to recover
a clocking rate from the data.
Alternate mark inversion (AMI) provides the same
characteristics.
But while all of this is indeed very interesting
stuff... it has *nothing* to do with analog vs. digital
or the definitions of either. I don't see any point to
your discussion.
Using synchronous
That is one way to do it, but there are others.
There would be no way *only* if you select an encoding
scheme such as NRZ. Manchester encoding provides for
easy clock recover, but so do other encoding schemes.
That is not true. Consider AMI using B8ZS encoding...
didn't get through.
Of course. But it has *nothing* to do with the amplifier
being analog. There *are* analog amplifiers that will not
destroy it. (And that is no different for analog data either,
which will also be destroyed if the amplifier does not have
suitable characteristics to pass it.)
Don't ignore what has already been made clear!
others can't.
But is has nothing to do with analog vs. digital. If the
amplifier cannot handle the signal's bandwidth, it makes no
difference if the signal is analog or digital, it will not
"pass" the data from input to output.
You are trying to impute something to digital that is
actually common to analog as well.
F
Floyd L. Davidson
analog.
That is not correct. Whether a message is or not
digital is entirely unrelated to whether the signal used
to transmit it is analog or digital (and it can indeed
be either, without regard to the message).
"Message" specifically means a complete set of data
formatted for transmission, and is not related to
analog/digital data signals.
For the term "signal", you can choose from several
definitions (FS-1037C):
signal:
1. Detectable transmitted energy that can
be used to carry information.
2. A time-dependent variation of a
characteristic of a physical phenomenon,
used to convey information.
3. As applied to electronics, any transmitted
electrical impulse.
4. Operationally, a type of message, the text
of which consists of one or more letters,
words, characters, signal flags, visual
displays, or special sounds, with prearranged
meaning and which is conveyed or transmitted
by visual, acoustical, or electrical means.
Hence you can see that using "message" and "signal" in
the same sentence is bound to cause confusion in the
context of this particular discussion. It simply does
not mean what you were thinking of. When used properly
the terms "signal" and "message" would be something like
this, "Our actions are intended to send Congress a
message, and we wish to signal our intense displeasure
with corruption."
But we've been discussing signals that meet either
the 1st or 2nd definition above, and specifically not
numbers 3 or 4.
In context, the signals are either digital or analog,
and which they are depends mostly on whether the data,
or individual parts of the information (message) that
the signal carries, is digital or analog.
F
Floyd L. Davidson
Really? Nothing could be acoustical? Are you deaf?
Regardless, that does not address the incorrectness of
stating that all signals are analog. Morse code is not
analog.
M
Mr.T
values,
OK, prove it.
Only for those who failed mathematics at high school.
MrT.
I
isw
You specifically mentioned "wire cables and fiber optic cables", so lets
talk about those and ignore other possible transmission media.
In both of those (as they are actually used in the real world),
communication is accomplished by the propagation along them of
electromagnetic fields; never anything else.
Doesn't matter one whit whether you turn the field on and off, or vary
the amplitude or any other characteristic of it continuously, as a means
of sending a message from one end to the other, those fields can take on
*any value* from the maximum level injected into the cable by the
transmitter down to far below the ambient noise level, depending (for
example) on the length of cable being used. IOW, those signals are,
without exception, *analog*.
Isaac
I
isw
analog.
The carrier or tone that is keyed on and off to send the code starts out
at a certain strength at the transmitter and grows weaker in a
continuous fashion as the receiver moves further and further away, until
at some point it becomes impossible to understand the *message* it is
carrying.
That is, the signal is analog. How can it be digital if it can take on
*any* value?
Isaac
F
Floyd L. Davidson
Mr.T said:
OK, prove it.
Eh? You seem to have misunderstood what was said. It
has *nothing* to do with resolution.
It has to do with the fact that no matter what level the
noise is, it could be either a little bit more or a
little bit less. That means whatever value you think
you have resolved, could in fact actually have had two
other possible values.
Which of course means that the number of voltages
between 3 and 18 is indeed infinite, with or without
noise.
Your ability to resolve those values is an entirely
different topic.
Add a random number with an infinite range of possible
values to *anything*, and you have a result with an
infinite range of possible values. Pretty simple math.
I'm sorry to hear that you didn't do well with math in
highschool.
F
Floyd L. Davidson
Yes, the electrical fields can take any value. It is
inherently an analog medium. But that has no
relationship to the signal which is used to send a
message.
The *signal* does or does not have the ability to take
on various values. If the signal uses discrete symbols,
it is a digital signal. If the symbols have a
continuous range of values, it is an analog signal.
This is not an insignificant distinction. It precisely
the reason that at Bell Labs Claude Shannon studied the
theory of how the two differ. As a result of his Theory
of Information the telecommunications industry began to
develop the technology required to implement digital
system to replace the existing analog systems. They did
that based on what Shannon had shown to be theoretically
the most effective for telecommunications.
Digital systems typically trade SNR (which can be very
low) for bandwidth (which will be very high) compared to
using analog signaling.
The inherent noise immunity of a digital system is
great, and because the analog noise in the medium is
*not* directly proportional to the signal value, a
digital signal can be transmitted with zero errors (due
to noise) if the SNR on the analog medium is above a
minimal level. It happens that that SNR is so low that
a system using analog signals would be unusable at the
same SNR. (Fiber optic cables are an example, where
they are virtually useless with analog signaling for the
typical long circuit lengths that are provided when
digital signaling is used.)
The actual minimum SNR depends on the type of digital
encoding used. But some typical values for various
communications purposes are interesting to look at. A
dialup telephone connection is supposed to have at least
a 24 dB SNR. That is relatively useful for voice
communications, but a typical dialup modem won't work
very well unless the SNR of the connection is above 30
dB above random noise (because it has been converted to
a bandwidth limited analog signal).
On the other hand a binary polar signal (such as the
RS-232C digital interface to that dialup modem) will
have an error rate of less than 1 in 10^5 with an SNR of
only 9.5 dB.
But that isn't even the most significant benefit! Noise
is additive on an analog system, but not on a digital
system, which is specifically the difference between
digital and analog that has revolutionized all
telecommunications in the years since Shannon showed
that digital was superior.
What that means is if we use 5 analog channels tandem
linked to get our message from one location to another,
the end to end noise must be added to determine the SNR,
and that total SNR must meet the above criteria for a
higher SNR than is needed by a digital system.
But if 5 digital channels are tandem linked, only the
errors are additive and not the noise.
That is, with analog both the noise and the errors in
the first link are sent to all succeeding links, and
that noise causes errors in each link on analog system.
On a digital system only the errors are inputted to the
succeeding links but not the noise, so noise in the
first link does not cause errors in the succeeding links
as it does with an analog system.
No, those signals are digital if the symbols they use
are discrete. The fact that the voltage, for example
can range from 0 to 1 volt has no significance in terms
of the signal *if* that signal uses exactly two symbols,
one of which is represented by any voltage less than 0.4
volts and one of which is represented by any voltage
greater than 0.6 volts. That describes a digital signal
(which indeed is being sent through an inherently analog
channel).
encoder medium decoder
input >----+ +---------------+ +----> output
|<---Analog --->|
| Channel |
|<--------------- Digital -------------->|
| Channel |
Typical examples of the above are where the input to the
"encoder" is a DS1 and the "medium" is a twisted pair
cable, or where that input is an OC3 and the "medium" is
a fiber optic cable, or where the encoder is a satellite
modem and the medium is a "bent-pipe" geosynchronous
satellite.
F
Floyd L. Davidson
I should have put a smiley on that, sorry for missing it.
Morse code does not necesarily have either a carrier or
a tone involved, but we can ignore that for this
discussion without changing the validity of our
conclusions.
carrying.
Well, lets take exactly that as an example, because it
is a good one. We could use a tone as the carrier if
you like, and send it down a regular twisted pair cable.
I'm going to describe this for Morse Code signaling, but
I'd like to point out that virtually any FSK modem does
exactly the same thing with exactly the dynamic range
I'm describing here. Instead of on/off though, it uses
two tones. Everything else is the same, except the
modem is many times faster than a human can decode Morse
Code.
If we put it on the cable at 0 dBm, we'll likely have an
SNR of roughly 50 dB or so, plus or minus a few.
The message is sent using on/off keying of a tone, so at
the cable head we have a 50 dB range which is used to
determine on vs. off. If we head down the road several
miles and get to a point where the signal level has
dropped 10 dB (about the maximum that can be used by a
POTS line), we now have a 40 dB SNR range to deal with.
We could go twice that distance again (losing 10 dB of
signal each time) and get to a point where our signal is
-30 dB and we have only a 20 dB SNR.
At 20 dB SNR there is no reason at all that you won't
get perfect copy, with no errors. Clearly the *signal*
has not changed, even though it has dropped 30 dB in
power. That is because the symbols used are discrete.
From perhaps -40 dBm to 0 dBm there is *no* *change* *in*
*the* *value* *of* *the* *symbols*!
*any* value?
Obviously it does *not* take on any value. The value
for Morse code is either on or off. There is no "on at
-22.4 dB" value, just on.
