P
Paul Ciszek
I have a detector with pairs of output lines: Q and Q NOT.
I am told that I need to look for a 5V difference between Q and Q NOT
in order to record an event; just watching for Q going high is not
good enough, Q NOT has to go low at the same time. This is in order
to separate signal from noise. These pulses should last for 2us give
or take a us.
I am told that a Differential Line Receiver should be able to do
this; however, the data sheet for one such:
http://focus.ti.com/lit/ds/symlink/sn75115.pdf
....leads me to believe that the output goes high whenever A goes
higher than B, not when A is some threshold higher than B. Can
one of these be jiggered to use a fixed voltage threshold, i.e.,
the output goes high only when A is 4 volts higher than B?
The other approach would involve op-amps used as a differential
amplifier and a schmidt trigger. Can anyone recommend an op
amp that would respond quickly enough? Single supply would be
nice, though not absolutely necessary.
or take a us.
