Question regarding using a plug adapter.
Discussion in 'Power Electronics' started by edwardkim89, May 3, 2021.
  1. edwardkim89
    edwardkim89
    May 3, 2021
    Hello there,
    I am looking into buying 2 continuous LED lighting from Nanlite.
    One is Forza 300 and the other is Forza 500.
    https://www.bhphotovideo.com/c/product/1476381-REG/nanlite_12_2001_forza_300_led_monolight.html
    https://www.bhphotovideo.com/c/product/1476382-REG/nanlite_12_2026_forza_500_led_monolight.html
    I'm buying through ebay, because it ships to South Korea (where I'm currently based), and it's cheaper than buying
    from local electronics stores in South Korea.
    But the thing is, it only comes with 3-pin AU 230V plug power cable.
    And we use 220v in Korea. So I would have to buy a converter.
    I know Forza 500 and 300 are strong lights, and I was wondering
    if it's safe to use the plug adapt or do I need something like a step up & down transformer?
    Edward
  2. bertus
    bertus Moderator
    1,694
    655
    Nov 8, 2019
    Hello,
    Did you read the specs?
    Power
    AC Input Power 110 to 240 VAC, 50 / 60 Hz
    DC Input Power 48 VDC
    Power Source AC Adapter, External Battery
    Bertus
  3. edwardkim89
    edwardkim89
    May 3, 2021
    Hey Bertus, thanks for you reply.
    Does that mean it's OK?
    Sorry, I'm not well educated on these things.
  4. bertus
    bertus Moderator
    1,694
    655
    Nov 8, 2019
    Hello,
    Any supply voltage for the adapter between 110 and 240 Volts AC will work, so the 220 Volts in your area is no problem.
    Bertus
    edwardkim89 likes this.
