Question for Altium Designer Users....
Y
yy7d6
Hi, I'm currently having problem with the PCB trace length
matching... I already set-up the 'Match Length Rule' and click on
Tools>>Equalize Net Lengths. but still nothing happens? I've
intentionally pre-routed the nets to be unequal in length to see if its
works... Any suggestions? --yy
B
Brad Velander
Try unrouting at least a portion of the traces.
If they are completely routed I am not sure that the command will do
anything, afterall it is basically a router function. It probably should
because you have to run it over several iterations when I believe it would
be routed after each iteration. Are the traces you routed "locked", so the
router won't touch them? Many possibilities but I can't answer them for you
because I don't use that function, nor the newer software.
Other than that, read the PDFs under the Help/About menu and go online
to Altiums site and check their PDFs and white papers. Failing all else,
register on their users forum, you will probably get your answers inside of
1 hour through their user forum. If you just ask your question here every
couple of weeks you may never get an answer.
