Question about zener voltage
Discussion in 'Electronic Basics' started by Bill, Dec 29, 2003.
  1. Bill
    Bill Guest
    Is it the case that two 12 volt zeners in series will act like a 24 volt
    zener?
    Bill
  2. Ian Stirling
    Ian Stirling Guest
    Barring some minor differences in temperature coefficiant, forward
    voltage and the wattage being doubled, it's the same.
  3. John Fields
    John Fields Guest
  4. Jerry G.
    Jerry G. Guest
    Considering that the efficiency specs are very close this will work. If you
    put them back to back you will have a bi-directional effect of the voltage
    rating of the active Zener plus the diodes conductive loss. This is usually
    about 0.6 to 0.7 Volts.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    zener?
    Bill
