R
[email protected]
I read an article intruducing the principle of VFD at:
http://www05.abb.com/global/scot/sc...52573070053da9e/$file/lvd_eotn01u_en_reva.pdf
When I read it, I do not understand the line:
"As long as this ratio stays in proportion, the motor will develop rated torque."
It means that we only change the frequency to drive the motor to change thetorque?
It seems there is also a method to change the AC voltage to drive the AC motor (I am not sure that there is the precise statement, but I think theoretically it can change the on/off time to change RMS voltage at the motor). That VFD introduction does not include voltage variation?
Fig. 5 shows
the torque-developing characteristic of every motor:
the Volts per Hertz ratio (V/Hz). We change this
ratio to change motor torque. An induction motor
connected to a 460V, 60 Hz source has a ratio of 7.67.
develop rated torque. A drive provides many different
frequency outputs. At any given frequency output of
the drive, you get a new torque curve.
Fig. 5 shows
