So I'm building a small device that will be powered by a 8.4v power source.
The problem is I want to add in a micro-vibrating motor but the motor I want to use runs off of 0.9v -1.6V. And I would like to run the motor slow. I believe the motor runs at 65ma typically.
Here is the motor I will be using:
http://www.elept.com/4mm-x-8mm-vibration-pager-vibrating-vibrator-motor_p2532.html
Space is extremely limited so I can only use a single resister or diode to drop the voltage/current.
I would appreciate any help that anyone could give me on this matter.
