P
Patrick Leonard
I'm studying electrical engineering and I've learned that inductors and
capacitors introduce a -/+ 90 degree phase shift between the voltage and
current. But lets look at an inductor with just a single loop - no tricks
here, just a wire that loosely forms a single turn (pick up your mouse cord
and try it). Such an arrangement most certainly does not produce a 90deg.
phase shift. I'm sure you can see where I'm going with this - at what point
does an inductance cause a 90-deg. phase shift in a circuit? Presumably,
for any given frequency, w, there would be a particular inductance
(ultimately, a particular geometry) that would be required for a full
90-deg. phase shift. Is what I've said so for correct? Does the magnitude
of the inductance have some correlation to the magnitude of the phase shift?
(It must...)
In that case, how does one calculate the 90-deg phase shift inductance?
If this is true, why is that inductors are modelled as |x|<90 in phasor
notation (ie, magnitude of reactance at an angle of 90) -- as this will
ALWAYS yield a 90-deg. phase shift in circuit analysis...despite the fact
that the inductor, may not in fact produce such a phase shift!
As noted, this is something I'm studying but don't really understand.
Please feel free to use math to explain.
PS. This is leading up to another question
(It must...)
