Question about power supplies ?
Discussion in 'Electronic Basics' started by isr, Nov 13, 2003.
  1. isr
    isr Guest
    I was wondering if someone could hazard a guess as to what sort
    of power supply circuit I have. Here are the clues:
    - voltage 0-15V
    - current 0-3A with current limit facility/dial
    - input voltage 230V 50Hz (i.e. Europe system)
    - there is a large heat sink with two 2N3055 power T's connected in parallel
    - when the voltage is increased above around 6V there is an audiable click
    due to the relay inside, see picture
    - there are 4 diode bridge circuits, see top left, top right, and two at bottom right,
    see picture
    - other active components are L7809CV x 2, L7812C, LM741CN,
    D313, LM324N, C1008 x 2, TL431C, see picture
    - the transformer seems to have 4 outputs, i.e. 2 lots of three wires plus two lots
    of 2 wires
    - picture of pcb is here : http://www.geocities.com/psuinternals/psu.jpg
    I am curious as to how this psu works, and I was hoping someone would
    know looking at the above points and save me to try and recreate the
    schematic. Also, it seems this circuit does not use one of the more modern
    ic's such as the L200C and instead uses fixed regulators such as the L7809 9v
    regulator, the L7812 12v regulator, plus 4 op amps in LM324N plus another
    741 op amp. Why anyone would want to use a 741 nowadays is a mystory.
    Also used is a variable zener diode - TL431C, and 2 bipolar T's - C1008.
  2. [snip]
    Because they're cheap. Real cheap, and work just fine for DC PSes.
    You didn't even give a make or model number.
    @@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@,@@[email protected]@[email protected],@@[email protected]@[email protected]@[email protected]@
    ###Got a Question about ELECTRONICS? Check HERE First:###
    http://users.pandora.be/educypedia/electronics/databank.htm
    My email address is whitelisted. *All* email sent to it
    goes directly to the trash unless you add NOSPAM in the
    Subject: line with other stuff. alondra101 <at> hotmail.com
    Don't be ripped off by the big book dealers. Go to the URL
    that will give you a choice and save you money(up to half).
    http://www.everybookstore.com You'll be glad you did!
    Just when you thought you had all this figured out, the gov't
    changed it: http://physics.nist.gov/cuu/Units/binary.html
    @@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@
  3. isr
    isr Guest
    the make is Tatoo, how this will help you I do not know.
  4. isr
    isr Guest
    it's a current model, 2003!!!
  5. Luhan Monat
    Luhan Monat Guest
    An old one.
