question about ohm's law
Discussion in 'General Electronics Discussion' started by Chengjun Li, Apr 5, 2015.
  1. Chengjun Li
    Chengjun Li
    84
    7
    Oct 21, 2014
    About Ohm's law, wikipedia has the following statement
    “Materials and components that obey Ohm's law are described as "ohmic" which means they produce the same value for resistance (R = V/I) regardless of the value of V or I which is applied and whether the applied voltage or current is DC (direct current) of either positive or negative polarity or AC”
    We also know that resistance of a resistor is a function of temperature. For example, Jameco 100 Ohm resistor has a temperature coefficient of 350ppm.
    My question is at higher voltage, the heat generated is larger due to P=V2/R, so the partial temperature is higher, then the resistance should change to smaller value, which is conflict with above statement of Ohm's law. Could anyone give me some clue of this problem?
    Thanks.
  2. ramussons
    ramussons
    374
    71
    Jun 10, 2014
    The blue statement is valid on a condition that all other parameters are constant - temperature, pressure, frequency, ... The only variables are the Voltage / Current.
    davenn likes this.
  3. alex Chiu
    alex Chiu
    14
    3
    Apr 1, 2015
    Ohm Law still value.
    P=VI, =
    If R = Constant, Higher V, higher I, however, when consider heat, R reduce, I reduce,
  4. davenn
    davenn Moderator
    13,802
    1,941
    Great response Ramussons .... spot on :)
  5. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    should be
    then the resistance should change to higher value
  6. Ratch
    Ratch
    1,093
    334
    Mar 10, 2013
    You should read this link http://www.electro-tech-online.com/threads/ohms-law.430/page-2 starting with my contribution on post #22. Then we can discuss it further.
    Ratch
