Question about off the self "Plasma Globes"
Discussion in 'Electronic Basics' started by B Ghostrider, Sep 10, 2004.
  1. B Ghostrider
    B Ghostrider Guest
    The other day I was at the local thrift store and found in the
    electronic stuff the base unit for a plasma globe. I got it for 25
    cents. At home I took it apart and looked over the Eletronic past ,all
    seamed to be good. I was wondering if it was possible use the part
    from the unit to make a JACOBS LADDER. From what I have seen on the
    net the eletronic component are the same. Both need a flyback
    transformer and a couple power tranistors. The rest of the compments
    that are on the board of the Palsa Glode seem to be for a osolater to
    vary the freq. of the voltage. This I have seen in so schematic for a
    "climding spark". In my opionin It should work. Shouldn't it??
  2. Si Ballenger
    Si Ballenger Guest
    Making a "violet wand" might be more fun. ;-)
  3. B Ghostrider
    B Ghostrider Guest
    I was whating to do a Jacobs Ladder because of Halloween.
  4. dan
    dan Guest
    What's that Lassie? You say that B Ghostrider fell down the old
    sci.electronics.basics mine and will die if we don't mount a rescue by
    Fri, 10 Sep 2004 16:31:12 -0700:
    Go to the local dump, or to the back lot of the local oil heat service
    place. Get the ignition transformer from a scrapped oil burner. It
    will put out about 10kV ac. from 110vac.
    Be careful.
    Dan
