Question about Modelling the ESR of a Capacitor
Discussion in 'Electronic Basics' started by K2, Apr 6, 2007.
  1. K2
    K2 Guest
    Hi Guys,
    under:
    http://www.avxcorp.com/docs/techinfo/eqtant.pdf
    you can find some basics about the 'ESR' of a Capacitor.
    A formula is shown describing the 'ESR' as: Rp/((2*Pi*f*Cp*Rp)^2+1)
    and the 'ESC' is : Cp+1/((2*Pi*f*Rp)^2*Cp)
    I guess, that the basic model looks like this:
    || __________ __________
    --------o----------||--------o-----|__________|-------|==========|----
    | || Cp | Rs Ls
    | ___________ |
    |---|___________|----|
    Rp
    My first Questions:
    Is the formula for the ESR correct??
    Paralleling Cp and Rp should result into an impedance of:
    Rp/sqrt(1+(2*Pi*f*R*C)^2)
    Or NOT????
    My second Question:
    I don't have a glue how the 'ESC' has to be calculated at all.
    What is the idea behind that?
    So long
    Karsten
  2. John  Larkin
    John Larkin Guest
    ESR = Rs.
    I have no idea what ESC stands for.
    Avoid tantalums. They tend to explode.
    John
  3. Phil Allison
    Phil Allison Guest
    "K2"
    ** The formulae applies to fig 4 which shows a perfect capacitor in
    parallel with a resistor.
    ** No.
    Fig 4 does not show what you drew.
    ** For the case shown in of fig 4 only.
    ** To make the parallel and serie scircuits bahave the same at the frequency
    of interest.
    Same impedance and same phase angle.
    ........ Phil
  4. Jean-Yves
    Jean-Yves Guest
    some beginning of the answer... :
    http://members.ozemail.com.au/~bobpar/k7214.pdf
    regards,
