Question about double layer capacitors
Discussion in 'General Electronics Discussion' started by TallPaul, Aug 7, 2015.
  1. TallPaul
    TallPaul
    11
    4
    Oct 5, 2014
    I had to replace a leaky 0.1F double layer capacitor in a device and was wondering if the new part measured correctly. I ordered Panasonic part EECS0HD104H for the replacement but it only measures 35uF using a digital multimeter. Are these type of capacitors tested a different way? I bought the capacitor from a US seller with an outstanding reputation rating
  2. AnalogKid
    AnalogKid
    2,482
    715
    Jun 10, 2015
    You don't say what meter you are using, but if you look up its specs it probably has a max-min range for the capacitance function. I doubt that 0.1 F is within its range.
    ak
  3. TallPaul
    TallPaul
    11
    4
    Oct 5, 2014
    the meter maximum is 200uF. I was curious to see if it would max out the meter and it didn't. when I measure caps over 200uF it always maxes out. I didn't expect a 0.1F cap to read 35uF
  4. AnalogKid
    AnalogKid
    2,482
    715
    Jun 10, 2015
    "The rich are different" - F. Scott Fitzgerald
    So are ultracaps.
    ak
