Question about copper conductor size.
Discussion in 'Electrical Engineering' started by Peter Jason, May 8, 2006.
  1. Peter Jason
    Peter Jason Guest
    I have a large electric oven rated at 15KW
    resistive load, plus another 3KW for 3-phase
    induction motors.
    Say 18KW total continuous running.
    All this has to be connected to a 3-phase
    supply in delta.
    How can I determine the conductor size for
    each of the 3-phase connections in Amps?
    Please help, Peter.
  2. Peter Jason
    Peter Jason Guest
    message
    PS the 3-phase is 415V
  3. Peter Jason
    Peter Jason Guest
    "TimPerry" <>
    wrote in message
    Many thanks; The electrician left out the
    SqRt3=1.732 in the denominator.
    I get Amps = 18000/(1.732 x 415) = 25amps /
    conductor
    Regards
  4. Guest
    I get 8ga copper. 31.3a
    (using the 1.73 factor to account for 3p, and 125% of computed load)
  5. Peter Jason
    Peter Jason Guest
    message
    It runs continuously and unattended during
    the off-peak tariff times at night.
    It is used for the melting the contents of 4
    x 200L (55usg) drums on standard pallets.
    It has forced-air circulation directing hot
    air to the underside of each drum via air
    injectors, by means of a hot-air blower.
    It operates at up to 110degC.
  6. Guest
    You are looking at MI cable now. How is your wallet ;-)
    6ga MI will be plenty, you still might be able to get away with 8 but
    it is shaky
