Question about Capacitors
K
K2LRV
OK here is a question that I have never seemed to find some at least
good guidelines on. What type of capacitor to use, i.e. electrolytic,
tantalum, ceramic, etc.
D
DJ Delorie
Don't use ceramic with high ripple currents, if you want them to be
quiet. They can act like tiny piezo buzzers. I used a big
electrolytic with a smaller tantalum in that case, no noise at all.
E
Eeyore
Oh God !
Buy a book !
Graham
E
Eeyore
Ceramics are NEVER used with high ripple currents you brain dead
defective.
Go away and die.
Graham
Jamie
Eeyore said:
defective.
Go away and die.
Graham
Oh really..
Tell that to the military customers that required us to
test the ripple currents on ceramic caps back when I was at
Semco.
We didn't actually make the ceramic material there how ever, we did
complete the rest of the cap's structure.
The main line was mica epoxy dips with very high Q.
Think before you speak!, not every one makes only audio circuits.
http://webpages.charter.net/jamie_5"
E
Eeyore
DJ said:
Wow, someone's off his meds again.
Provide an example of a ceramic caps with high ripple current before
talking out of your arse.
Graham
E
Eeyore
Mica caps with very high ripple currents ?
Bwahahahahahahahahahhahah
D
DJ Delorie
That would go against my original recommendation.
D
DJ Delorie
That is, providing an example of ceramics used in a
high-ripple-current situation would go against my original
recommendation.
A
Andre Majorel
defective.
Go away and die.
Is that the real Graham Stevenson or a forgery ? The Path: looks
genuine to me.
E
Eeyore
Jamie said:
You absolutely do not know what you're talking about..
Stop embarrassing your self and move to a different subject.
Please post ripple current ratings for mica caps.
I look forward to seeing one that can handle say 10A !
MORON
Graham
E
Eeyore
genuine to me.
It's genuine.
Anyone who thinks you use ceramic caps as reservoir caps needs their
brain examined.
Graham
Jamie
Lostgallifreyan said:
Are there no other situations where ripple current matters? Perhaps unusual
power HF systems?
Don't mind the Ham, I mean Graham, he's living in the audio world only.
I think anything above 50 Hz is challenging to him.
Btw, we used 1 Mhz signals in faraday cages at various levels of power
to test ripple currents..
1 Mhz was also the freq used in most of the other test.
P
Phil Allison
"Lostgallifreyan"
Eeysore to Fake
unusual
power HF systems?
** The " ripple current" rating matters whenever ANY capacitor is passing
significant amounts of current - such that its ESR causes it to self heat.
Cap makers do not publish ripple current figures for all types, but usually
do publish ESR values and curves from which the amount of self heating can
be calculated - at least approximately.
Ignore this at your peril - eg:
The common X cap for mains suppression is well designed for its job, with
250 volts AC at 50 or 60Hz - but what say if you apply that same voltage
at 10kHz ??
Answer - it smokes and explodes.
...... Phil
E
Eeyore
power HF systems?
Can you be more specific ? At medium HF, polypropylene is a good dielectric to
use and since values tend to be lower at HF, not a problem size wise. I've put
8-10A though a relatively small polyprop cap.
Graham
