Question about building small device with touch sensors
Discussion in 'Sensors and Actuators' started by Brewhaha, Mar 1, 2017.
  1. Brewhaha
    Brewhaha
    Mar 1, 2017
    What exactly would one need to just create a basic touch sensor that would send a command/signal to the PC via usb cable ? Kind of like a game controller. Actually, make it multiple touch sensors like some of those square force sensitive resistors over at adafruit (just a square pad slightly larger then a quarter). So something like each sensor plugs into a single board which has a usb cable wired into it as well. Can it be that simple ?
  2. BobK
    7,682
    1,686
    It's what goes between the sensor and the USB cable that is complicated.
    You can buy a USB GPIO board that has analog inputs, this might do the trick.
  3. OBW0549
    OBW0549
    159
    118
    Jul 5, 2016
    Yes, it can.
    I would suggest using a capacitive touch sensor, such as this five-channel unit, along with a small, no-frills Arduino-like board such as this one to process the touch sensor state and report it to the host PC over USB.
    The rest is a SMOP (Small Matter Of Programming).
