P
Peter Smith
I'm trying to check out a Quasar VCR for a relative. The unit plays, but the
picture is badly garbled and the flow of the tape through the machine seems
to fluctuate every now and then. When just watching a TV channel through
it's tuner the picture also fluctuates. I was thinking that the power supply
was possibly going bad, how do I test it? I've found a diagram that shows
pins 1, 5, and 6 should all show 5.1 volts, but which other pin should I
connect to to measure the voltage? Should I pull the supply out and try to
measure the voltage without the mainboard connected or should the supply
have a load on it while testing?
Any help would be much appreciated, thanks.
