quadrature singal
westpoint
Feb 19, 2012
5
Feb 19, 2012
5
Hi folks, I am working on a big project. One of the most important steps is to produce sin and cos (quadrature singal) singal. The singal must be low-noise and the frequency of the two singals can be controlled by computer, i.e.
computer (gives a votalge V)--> circuit --> analog sin(A*V*t) and cos(A*V*t)
the votalge given by the computer is between -10 and 10 V. And A is some constant factor determined by the circuit.
can we do that?:)
twister
Feb 12, 2012
172
Feb 12, 2012
172
can we do that?:)
Be careful not to produce too much sin, :eek: you will have to ask Jesus to forgive you, if you want to go to heaven. ha
Sine waves I know. Cosines, not much. Someone smarter than me will have to help you on that. :D
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
westpoint said:
The expected frequency is 20KHz and it should be very stable with less than 1Hz noise. And A is just some factor, so A*V is around 20KHz.
So the real problem is not quadrature generation but rather building a very stable voltage-controlled oscillator. From your answer I gather that the VCO signal is not sin(A*V*t) but instead sin(A*{K+V}*t)=20khz where K>>V.
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
GonzoEngineer said:
BTW....it is spelled signal.:cool:
Rats! I was fascinated by the prospect of low-noise sin with SinGal, and the magnitude of the forgiveness I would seek.
